spreedsheet
Theis1977
spreedsheet
Post by Theis1977 »
Hallo im total new in freeCad.
but old user in inventor + solid+ creo
I have a bit advance quastion and try to explain as good as i can.
In a part you can insert a spreed sheet and controle ex lenght ect.
What can you control in a asm + spreed sheet ?
The video i found on youtube i look like you can controle ex, constraint / angles ect. placement.
But can you in a asm level controle part sketch ?
Best regard Theis
Re: spreedsheet
Moved to Assembly forum.
Help the helpers by providing more detailed information of what you want.
Theis1977
Re: spreedsheet
Post by Theis1977 »
Moved to Assembly forum. ( thanks )
I like to know what you can controle in a spreedsheet in asm level ?
can you controle parts sketch ?
Or can you only controle constraint between parts ect.
Best regard Theis
Zolko
Re: spreedsheet
Post by Zolko »
Theis1977 wrote: Fri Nov 19, 2021 1:38 pm I like to know what you can controle in a spreedsheet in asm level ?
In Asm4, yes (with variant-link) but I recommend to rather use the variables container, much more user-friendly.
Theis1977
Re: spreedsheet
Post by Theis1977 »
i will read about it.
Do you have any good video link about it :) ?
