In A2plus I want to re-import a part, of which the length of the basic pad has been changed. But A2plus keeps importing it with the old length. Whether I use the Import button, or delete the part and import it again, the result is the same: the part is imported with the old length.
Shutting down and re-opening the A2plus session, or Freecad altogether, doesn't help too.
When I open the part with Part Design, the correct, new length is shown.
What goes wrong here?
Version info on Freecad:
OS: openSUSE Tumbleweed (KDE//usr/share/xsessions/plasma5)
Version: 0.20.26306 (Git) AppImage
Branch: (HEAD detached at 6701788)
Hash: 670178869ecdca52f7dcd332c513cb0c82b25cce
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Version of A2plus is 0.4.54b
best regards, jehojakim
Re-import part in A2plus loads old version of part
Re: Re-import part in A2plus loads old version of part
Could you provide the files in question?
Moved to Assembly forum.
Hereby the requested files.
I added the spreadsheet, because it contains the measures of the part to be imported (not of the assembly).
In he meanwhile I noticed that, when I unzip the MiddenbalkFCStd file (containing the definition of the part to be imported in the assembly), in various PartShape<X>.brp files there are occurrences of the old measure (being 655 mm), and also some (but less) to the new value (785 mm). So maybe that's confusing A2plus?
But I know nothing about the syntax of the .brp-file format, so I may be completely wrong here.
regards, jehojakim
regards, jehojakim
- Tafel-CNC-rekenblad.FCStd
- Spreadsheet containing measures
- (3.12 KiB) Downloaded 22 times
- Tafel-CNC-assembly.FCStd
- The assembly in A2plus
- (52.94 KiB) Downloaded 25 times
- Middenbalk.FCStd
- The part to be imported
- (27.15 KiB) Downloaded 28 times
