Let's say we have a PointsSymmetric constraint. There are 3 elements under this constraint in the tree view. If, say, the plane element breaks (caused by TNP) can you delete it and select a new plane for the constraint?
I tried doing this but when I click "Assembly->Create element" it says "Invalid element link".
Edit: what I would like to do is very similar to "Right click->Attachment editor" to change the attachment plane of a sketch.
Thanks.
Assembly 3: is it possible to fix broken elements for a constraint?
Re: Assembly 3: is it possible to fix broken elements for a constraint?
Just select new object you want to use as element and drag it...
https://forum.freecadweb.org/viewtopic. ... 12#p546995
I cannot tell you how much joy that has brought me. Thank you so much.bambuko wrote: ↑Thu Nov 18, 2021 5:53 pm Just select new object you want to use as element and drag it...
