There are many errors when I open the old ASM4 project file
My FREECAD version 0.2
My Assembly 4 Version 0.11.4
Ask for help...About Assembly 4 errors...
- xsuper9988
- ASM_ERROR_TEST70.FCStd
- (984.3 KiB) Downloaded 22 times
- ASM_ERROR_TEST70.txt
- (785 Bytes) Downloaded 23 times
- ASM_ERROR_TEST71.png (128.63 KiB) Viewed 2268 times
- ASM_ERROR_TEST72.png (73.94 KiB) Viewed 2268 times
- ASM_ERROR_TEST73.png (108.65 KiB) Viewed 2268 times
Re: Ask for help...About Assembly 4 errors...
These are not Asm4 errors, and this is not an Asm4 assembly : the parts (bodies and solids) are directly inside the assembly container, not linked. The arrays as and mirrors are not from the Asm4 workbench, but probably from Draft or Part WB.xsuper9988 wrote: ↑Fri Nov 05, 2021 2:17 pm There are many errors when I open the old ASM4 project file
- xsuper9988
Very sorryThese are not Asm4 errors, and this is not an Asm4 assembly : the parts (bodies and solids) are directly inside the assembly container, not linked. The arrays as and mirrors are not from the Asm4 workbench, but probably from Draft or Part WB.
I thought it was caused by ASM4
This is one of my SUB-ASM4
After I delete ASM4
Only the body and the solid are still wrong
But from the error message I can’t tell where the error came from
Thank you very much for your reply
- xsuper9988
I'm done testingThese are not Asm4 errors, and this is not an Asm4 assembly : the parts (bodies and solids) are directly inside the assembly container, not linked. The arrays as and mirrors are not from the Asm4 workbench, but probably from Draft or Part WB.
When i remove all the body and solid
And reopen the file and there is no error
I think it is caused by the difference of FREECAD version
FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1
FreeCAD_0.20.26155_Win-LPv12.5.4_vc17.x-x86-64
so...
I don’t know how to deal with this issue...XD
- ASM_ERROR_TEST74.png (105.44 KiB) Viewed 2075 times
- xsuper9988
I find issue topic linkThese are not Asm4 errors, and this is not an Asm4 assembly : the parts (bodies and solids) are directly inside the assembly container, not linked. The arrays as and mirrors are not from the Asm4 workbench, but probably from Draft or Part WB.
But their discussion seems inconclusive
https://forum.freecadweb.org/viewtopic. ... 7&start=10
