When Assembly4 link parts are in the folder
the MOVE function cannot be used
Because I have a lot of link parts(ASM_MOVE_TEST3)
I want to do classification management
Is there any other classification method
I can still use the MOVE function after classification
The situation is as shown below(ASM_MOVE_TEST1、ASM_MOVE_TEST2)
When Assembly4 link parts are in the folder, the move function cannot be used.
- xsuper9988
- ASM_MOVE_TEST3.png (134.06 KiB) Viewed 2162 times
- ASM_MOVE_TEST2.png (88.7 KiB) Viewed 2162 times
- ASM_MOVE_TEST1.png (85.18 KiB) Viewed 2162 times
Re: When Assembly4 link parts are in the folder, the move function cannot be used.
you're right, this is by design. This has been requested many times (see issue #189). Until now I have resisted to implement this for simplicity reasons.xsuper9988 wrote: ↑Thu Nov 04, 2021 3:46 am When Assembly4 link parts are in the folder the MOVE function cannot be used
Did you try with configurations ?I want to do classification management. Is there any other classification method
You set up what parts are visible, their offsets, and you create a configuration. You can do as many configurations you want: make a setup that you want to save, create the configuration, and you can recall it at any time: the assembly will show and hide as you have defined in your configuration. The AttachmentOffsets of the parts are also stored there, so you can make exploded assemblies (this tool was meant for assembly instruction steps)
- xsuper9988
SorryDid you try with configurations ?
Where can I find information about "configurations"
The classification method refers to "link parts"
"link parts" are too many...XD
As shown below (ASM_MOVE_TEST4)
- ASM_MOVE_TEST4.png (56.29 KiB) Viewed 2083 times
ah, OK, so it's not for that use-case. Why don't you use sub-assemblies ?xsuper9988 wrote: ↑Thu Nov 04, 2021 9:35 am The classification method refers to "link parts"
- xsuper9988
Do you mean like this?ah, OK, so it's not for that use-case. Why don't you use sub-assemblies ?
(ASM_MOVE_TEST51)
I ran into this problem here Most Linked Locations
(ASM_MOVE_TEST52)
I thought about it later
I should create more datum objects
To reduce assembly complexity
- ASM_MOVE_TEST52.png (153.04 KiB) Viewed 2050 times
- ASM_MOVE_TEST51.png (316.71 KiB) Viewed 2050 times
- xsuper9988
excuse me
I asked another question from a long time ago
I use a file "_P"
It only has "spreadsheet"
It is used as a global variable for all files
But it’s not very convenient to use
Need to be updated one by one
And I not only use three files
I use it in several files
I record and upload YOUTUBE
The situation is like this
https://youtu.be/9dGgE42m8hY
I use a file "_P"
- ASM_PARA_TEST64.png (185.49 KiB) Viewed 2035 times
- ASM_PARA_TEST63.png (136.72 KiB) Viewed 2035 times
- ASM_PARA_TEST62.png (257.47 KiB) Viewed 2035 times
- ASM_PARA_TEST61.png (100.88 KiB) Viewed 2035 times
- xsuper9988
Excuse me again
I have one more question
The project of "Assembly 4" uses "View Fit All"
CAD ratio will become smaller and smaller
This happened at 2:52 on Youtube
The above are most of the problems when I use "Assembly 4"
Thank you very much for your answers and assistance
