you could try to install a master version running on a stick and then copy the realthunder version over it, then everything could be there
Collection of differences between original master version and realthunder
- thomas-neemann
Re: Differences between original master version and realthunder
Re: Collection of differences between original master version and realthunder
Thanks for your reply - I made a mistake in my initial post - the VCRUNTIME140_1.dll and VCRUNTIME140.dll file was available in the DLL folder within the BIN folder, but not in the BIN folder itself.thomas-neemann wrote:
When I copied both files from the DLL folder, and pasted them directly into the BIN folder, now it worky OK.
Universal definition of truth applicable to ALL disciplines:
"Truth Does Not Contradict Itself"
- thomas-neemann
this bar can be switched off in realthunder.
here a workaround for master
I found that here
https://forum.freecadweb.org/viewtopic. ... 20#p263706
edit
can you start freecad with this python command as an option?
FreeCADGui.draftToolBar.Deactivated()
edit
- thomas-neemann
test: loading a large fcstd file (204 mb) . master aborted after 20 minutes due to memory overflow.
Version: 0.20.26306 (Git) AppImage
Branch: (HEAD detached at 6701788)
Hash: 670178869ecdca52f7dcd332c513cb0c82b25cce
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
realthunder approx. 5 min.
Version: 2021.1015.24301 +4280 (Git) AppImage
Branch: LinkDaily
Hash: 556c87868ea46796242156e9f73eae98259794b7
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
here is the test file (stp) that I saved as fcstd.
https://grabcad.com/library/isolation-g ... ing-line-1
https://www.youtube.com/watch?v=tiwl_suatd8
Qt version: 5.12.9
OCC version: 7.5.3
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
- thomas-neemann
in the master and in realthunder the catch function lights up in the yellow circle, but it is not caught. an error message is thrown. a point on the object is probably necessary beforehand in order to get the result.
in realthunder, the defining geometry function generates the desired result with one click
https://www.youtube.com/watch?v=95tRqX7P3EQ
Version: 0.20.26554 (Git) AppImage
Branch: (HEAD detached at 817c14b)
Hash: 817c14b16af681b06aec7d8c79f744c7a88fa3c3
Qt version: 5.12.9
OCC version: 7.5.3
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
Qt version: 5.12.9
OCC version: 7.5.3
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
- thomas-neemann
- thomas-neemann
to create this part,
it makes sense to edit the sketch from both sides, also in connection with
in the realthunder version on maped sketches "map reversed" is available
edit
in master also possible
edit
Since years!
- thomas-neemann
- thomas-neemann
deleted because it was wrong
Last edited by thomas-neemann on Mon Jan 24, 2022 5:10 pm, edited 2 times in total.
