Assembly 4 workbench
s-light
Re: Assembly 4 workbench
Post by s-light »
hasecilu wrote: Mon Apr 25, 2022 1:08 am I'm using a Link to make various copies of one fastener
i just played around with this..
(zip in attachment)
it works when you do it this way:
- create screw
- create link (in parts group)
- set link count 2
- drag drop the two sub-links into the assembly container
- select Link_i0 in Assembly and Click on Image
- select your target LCS
- done :-)
good think i had motivation to jsut try it and test out Asm4 ;-)
thanks for the motivation :lol:
sunny greetings
stefan
Asm4_links_Attached.zip
(728.63 KiB) Downloaded 54 times
FCuser2019
Post by FCuser2019 »
Haavard wrote: Sun Apr 24, 2022 8:41 pm
Thanks for reporting, here is the fix.
Zolko wrote: Wed Apr 20, 2022 9:57 am new version released today[/url] (v0.11.11)
Time for a v0.11.12 :oops:
Thanks for the fix :)
Zolko
Post by Zolko »
Zolko wrote: Wed Apr 20, 2022 9:57 am new version released today (v0.11.11)
Time for a v0.11.12
done, thank-you, can you please check that the regression has been fixed ?
Haavard
Post by Haavard »
Zolko wrote: Mon Apr 25, 2022 12:40 pm done, thank-you, can you please check that the regression has been fixed ?
Works as expected for me at least :) Thanks for the fast update!
mcdanlj
Post by mcdanlj »
hasecilu wrote: Mon Apr 25, 2022 1:08 am This "forget the Assembly4 way" is because I'm using a Link to make various copies of one fastener (because I don't want to manually change the parameters to every fastener).
Ah!
I don't know what I did wrong the first time I tried to move my fasteners into the Parts collection, but I must have dropped them in the wrong place. I now have it working.
In my case it seemed easier to set up a separate LCS for every location. Probably because I'm a novice. But it worked and animated correctly. Thank you!
mcdanlj
Post by mcdanlj »
mcdanlj wrote: Tue Apr 26, 2022 1:03 am I don't know what I did wrong the first time I tried to move my fasteners into the Parts collection, but I must have dropped them in the wrong place. I now have it working.
I finally realized that all the hardware that is supposed to move with a part should just be a separate body in the part it moves with. I have some inconsistencies in my model from exploring different options, but since I presented an earlier version, I thought I'd share what I got to so far in case it helps another neophyte like myself.
I used the realthunder build for this, and the current model is attached.
KeywayCutter.FCStd
(560.73 KiB) Downloaded 50 times
Zolko
Post by Zolko »
mcdanlj wrote: Thu Apr 28, 2022 10:18 pm I finally realized that all the hardware that is supposed to move with a part should just be a separate body in the part it moves with.
this is true if you want all your assembly in a single document. This is actually a particularity of FreeCAD, no other CAD package allows you to do this. Another approach would make you put all the hardware moving together in a sub-assembly in a separate file, and make the assembly from those sub-assemblies. For more complex models, you'll have no choice, you'll have to go the sub-assembly way.
But congratulations, you're using Asm4 exactly as it has been designed for.
I have this error message, I dunno if it's related (I use a source-compiled version):
22:06:11  SketchObject::onChanged(): Unmanaged change of Constraint Property results in invalid constraint indices
mcdanlj
Post by mcdanlj »
Zolko wrote: Thu May 05, 2022 8:17 pm this is true if you want all your assembly in a single document. This is actually a particularity of FreeCAD, no other CAD package allows you to do this. Another approach would make you put all the hardware moving together in a sub-assembly in a separate file, and make the assembly from those sub-assemblies. For more complex models, you'll have no choice, you'll have to go the sub-assembly way.
Thank you! Yes, I can see that this is about as complex an assembly as I'd want to have in a single document; naming things, changing sketch attachment, and so forth is hitting a limit.
One of the reasons I wanted it all in one document was that it made rich parameterization relatively easy.
I think that was an error that I've fixed since as I continued to refine the design. I don't want to spam the forum with every new FCStd version, but https://gitlab.com/mcdanlj/KeywayCutter has the save-as-directory latest, and if people want to see it I can upload latest as an FCStd file.
Zolko
Post by Zolko »
looking at your model, the part "Sleeve" is made of a part (yellow icon) that holds a "Sleeve" body (blue icon): this is unnecessary in Asm4, you can use PartDesign bodies directly as parts, you don't need to wrap them into parts (yes, I know it's confusing). If you have "parts" made out of several "parts" then your solution (putting several bodies into a part and assembling that part) is interesting.
mcdanlj
Post by mcdanlj »
Zolko wrote: Mon May 09, 2022 12:34 pm looking at your model, the part "Sleeve" is made of a part (yellow icon) that holds a "Sleeve" body (blue icon): this is unnecessary in Asm4, you can use PartDesign bodies directly as parts, you don't need to wrap them into parts (yes, I know it's confusing). If you have "parts" made out of several "parts" then your solution (putting several bodies into a part and assembling that part) is interesting.
Oh. Thank you. I just followed what I understood of Asm4_Tutorial1 and Asm4_Tutorial2, trying to adjust for the changes in vocabulary (like "Model" becoming "Assembly"). The "Bit" and "QCTPBlock" in my file are also like that.
I originally intended the "Shaft" as a single part, and realized later that I was going to want to add a grub screw to it. (Originally, I was going to use a very small taper to hold the bit, then for several reasons switched to a grub screw engaging a flat on the bit.) So if I had started with PartDesign bodies, could I have dragged them into Asm4_newPart parts later to add the grub screws to include in the Asm4 Assembly?
The purpose of the Asm4_newPart and Asm4_newBody actions is not clear to me. I've tried to read a lot of this thread but pulling fundamental concepts like that out of it is hard. What is the purpose of Asm4 Parts? (link to doc or earlier comment that I could have read would be awesome; I have read a lot and haven't understood this yet so it's not because I just didn't try. ☹)
