Oops. Forgot to create an icon for them. The one you saw is the default constraint icon. I guess they are not very popular constraints, so nobody really notice that for so long...FreeCutter wrote: ↑Fri May 14, 2021 7:32 pm Just a little issue which confuses me: why is the same icon used for different constraints?
Assembly3 preview
Re: Assembly3 preview
You can access 'Fix element' and 'Detach' actions in the tree view context menu. Just right click the element item in the tree.
Unfortunatelly it seems like Big Sur cannot open the Conda release (sorry for the late update on this).realthunder wrote: ↑Fri May 07, 2021 3:44 amSomeone else has reported same problem. Can you please try download my MacOS Conda release and see if it will crash too?skopjanecot wrote: ↑Thu May 06, 2021 1:05 pm My FreeCAD LinkBranch crashes when I try to open the Mesh Design WB.
i have create a model with a spreadsheet containing all important variables. Next I want to use different configurations of this model in an assembly from a different document. I know of this thread https://forum.freecadweb.org/viewtopic.php?f=17&t=42183, but struggle with implementing it. For now the only dynamic property I need is the length of my model. Is this at all possible?
Yes, it is possible. Expression has built-in support for referencing external object with syntax DocumentName#ObjectName.ProertyName, or if you want to reference by label (i.e. the user assigned names), then use the (kind of) strange double quote syntax, <<Document Label>>#<<Object Label>>.PropertyName. So you can use it anywhere to direct reference an external spreadsheet cell.Cyclonit wrote: ↑Wed Jun 02, 2021 8:56 am Hi,
However, for easy management, you may want to create a normal Link to the external spreadsheet in your modeling document first. And then refer to the cell through this link instead, with syntax ObjectName.PropertyName. The 'ObjectName' will be the link's object name. This way you can easily see which external spreadsheets are used, and can later on change the link to point to another one without having to modify all affected expressions.
I'm testing your -asm3 build, and here are some of my findings:
- When I load an existing model, the -asm3 branch asks me to migrate. I can imagine that it's for the toponaming stuff, but we're slowly coming to some incompatibilities between yours and the main branch.
- you seem to have dropped FreeCAD's original copyright claims: I have no opinion about that, just mentioning
- the load-time is much longer than with stock FreeCAD (seems stuck on "loading freecad.pip")
- with the same conditions and model, your branch has somewhat better performance (20 -vs- 30 fps). I have an Nvidia card that I run with the Nvidia Prime offload:
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia ./FreeCAD-asm3_20210615.AppImage
- I LOVE the small icons in the tree to show the state of objects, it's much better than the tiny overlays.
- I LOVE that at start-up, the combo-view remembers my view setting (hide the tree panel because I have another tree panel already)
- when I create a sketch and then cancel the attachment, I get an error:
15:40:03 TempoVis.restore: failed to restore detail ('SDPickability', 'Unnamed', 'Sketch_Part_3'): 'NoneType' object has no attribute 'ViewObject'
- concerning the topological naming, I tried with a sketch and a datum LCS attached to it. I created a square and attached the LCS to a corner and aligned on 2 edges. When I then set one of the other edges to "construction" I can see that the names of the edges has changed, but the attachment of the LCS has been adapted accordingly and thus doesn't fail. What I conclude is that the topological naming has changed BUT that FreeCAD follows that change and adapts the existing references to this change
- when I delete a line completely (not only setting it to construction) and add other lines to the sketch, then the same happens: the names of the edges change, but the references from the LCS are adapted.
Concerning the topological naming, I'll post on the relevant thread
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 2021.615.24301 +3584 (Git) AppImage
Branch: LinkStage3
Hash: d1e4d1c5abdedda669e54d1a41b5c08077f7e561
Python version: 3.9.4
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
What exactly is detach for? Is it some kind of 'disable'?realthunder wrote: ↑Thu May 20, 2021 2:36 amYou can access 'Fix element' and 'Detach' actions in the tree view context menu. Just right click the element item in the tree.
When should I use fix when detach?
So much functionality and I can not use it
Detach means to remove link to the source object, but the element shape is still retained, so the element can recompute fine and your assembly should just work the same. Use 'Detach' if your model has been changed so much that there is no corresponding geometry element to the old model. Because the element may be used by some upper assembly, to avoid potential solver failure, you can just choose to keep using the old element shape. Just keep in mind that a detached element will no longer follow any subsequent changes in your model.
'Fix' means to try to guess new geometry reference using topo naming, which may or may not work. The link to the object is kept.
We currently have a thread in the German subforum where someone tried to make an assembly where some screws should be aligned with holes in a cylinder. I made an example using Assembly 3.
My main issue was that I'm not able to use the hole itself together with the PlaneCoincidence constraint (or AxialAlignment constraint) because the shape of the hole is not planar. realthunder showed a workaround here:
This is how the object tree for the parts and the assembly looks like:
Is this the "best" way to do it or should I've done something differently?
edit: added link to thread in the German subforum
I was able to adapt this workaround for one screw. But since I've used PartDesign_PolarPattern, I didn't have a sketch for the other two holes already. Therefore I've added datum planes, used the holes to align the planes and created sketches to use them within Assembly 3 to align the two other screws:realthunder wrote: ↑Sun Feb 11, 2018 11:02 pm [...]
the reason why you can't simply use the circular hole in the rod is because the shape is not planar. You can use the sketch instead. And since it is a public geometry of the sketch, you don't need to use the edit mode, simply make the sketch visible, and select it. If you want the pin to be movable, use AxialAlignment constraint. Otherwise, you can use PlaneCoincidence.
- cylinder_align_screws_holes_Asm3_M4x.FCStd
- (167.21 KiB) Downloaded 93 times
Regards / Viele Grüße
Max
Max
