Alignment error of the "Select Floor" function
domad
Post by domad »
Greetings to the Community!
In order to create an animated * .gif that would show how to obtain a precise alignment of an "empty" Sketch, I came across this "serious" work plane alignment error through the "Select Plane" function.
Here are four example cases:
a) solid with hexagonal base obtained with "Part Design"
- using two coplanar edges, to define the plane, the work plane does not align, the same behavior if you use an edge and a vertex or three vertices.
- using a face, to define the plane, the plane aligns correctly
b) solid with a square base obtained from primitives "Part"
- using two coplanar edges, to define the plane, the work plane aligns correctly, the same behavior if you use an edge and a vertex or three vertices.
c) solid with a square base obtained from "Draft" (face) + "Part" (extrusion)
- using an edge and a vertex or three vertices.
using a face, to define the plane, the plane aligns correctly;
d) prism obtained using the "Additive Primitives" of "Part Design"
The animated * .gifs show the four cases mentioned above.
Some of the moderators / developers could kindly investigate (or open a ticket) about this bad and serious behavior of the "Align plane" tool when using solids modeled with "Part Design".
Thank you!
Version: 0.21.29365 (Git) AppImage
Hash: 59b945dcc329303ad781075ecf30544aab909415
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Local
solid with hexagonal base obtained with &quot;Part Design&quot;<br />- using two coplanar edges, to define the plane, the work plane does not align, the same behavior if you use an edge and a vertex or three vertices.<br />- using a face, to define the plane, the plane aligns correctly
solid with a square base obtained from primitives &quot;Part&quot;<br />- using two coplanar edges, to define the plane, the work plane aligns correctly, the same behavior if you use an edge and a vertex or three vertices.<br />- using a face, to define the plane, the plane aligns correctly
Case _b.gif (788.33 KiB) Viewed 1094 times
solid with a square base obtained from &quot;Draft&quot; (face) + &quot;Part&quot; (extrusion)<br />- using two coplanar edges, to define the plane, the work plane aligns correctly, the same behavior if you<br />- using an edge and a vertex or three vertices.<br />using a face, to define the plane, the plane aligns correctly;
prism obtained using the &quot;Additive Primitives&quot; of &quot;Part Design&quot;<br />- using two coplanar edges, to define the plane, the work plane does not align, the same behavior if you use an edge and a vertex or three vertices.<br />- using a face, to define the plane, the plane aligns correctly
domad
Re: Alignment error of the "Select Floor" function
Post by domad »
Version too
OS: Linux Mint 20.3 (X-Cinnamon / cinnamon)
Version: 0.21.29393 (Git) AppImage
Hash: 6820e0a9ec85203a6f342ca72a2ff8fd417beaf1
Local: Local
has the same problem
This should be reported in the Draft forum since it's the Draft working plane that misbehaves, not Part Design.
