- ISO 4762 + DIN 127
- DIN 7984 + DIN 127
[Feature Suggestion] Add more standard options to the "Hole cut" drop down in the Hole dialog
Right now the Hole dialog provides a lot of options for Hole cut
However, one option I would really appreciate is adding DIN 127 split washers (commonly known as "Grower washers") Common combinations would be:
Re: [Feature Suggestion] Add more standard options to the "Hole cut" drop down in the Hole dialog
fyi: DIN127 is retired, because its ineffectiveness (i can confirm that in RL).
(When having vibration, then DIN 6796, Loctite 243 (or equivalent) or schnorrdisc https://de.wikipedia.org/wiki/Schnorrscheibe is good).
Greetings
user1234
Greetings
user1234
I don't agree about using the "deprecated" concept here. Those options are still used in commercial CAD programs such Catia V5 (I have used it recently very often, and I hope to get a job and keep using it or other CAD ). They provide an option for custom measures.
I would use "(generic)" instead, also I would add the old DIN reference between parentheses:
The reason is that a lot of people know better the old DIN reference. I have seen screw boxes labelled as DIN 912 instead of the ISO reference, using both references would help the user.
I don't know if an additional icon can be provided, that would help the user a lot.
Countersink (generic)
EN ISO 4762 ("DIN 912")
Estudié ingeniería técnica industrial en España y sólo me ha servido para estar en el paro, no me contratan porque no tengo experiencia, y no tengo experiencia porque no me contratan. No debí estudiar esa carrera.
