0.20 bug/regression Array Pattern issue #6641
uwestoehr
Re: 0.20 bug/regression Array Pattern issue #6641
Post by uwestoehr »
jnxd wrote: Tue Apr 12, 2022 3:23 am [EDIT] Conveniently I just checked 15 seconds after posting this and the first file works with the following after a recompute:
It fails for me. This is what I get as result when I recompute the whole file:
Ad as I wrote the issue is independent on polar patterns, I cannot do any transformations with lofts and pipes, no matter if patterning or mirroring. With FC 0.19 this works.
Version: 0.20.28682 (Git)
Hash: a13e251ad45c3562875e6bcc8e1c7e84882a4d52
Python 3.8.6+, Qt 5.15.2, Coin 4.0.1, OCC 7.5.3
Locale: English/United States (en_US) [ OS: German/Germany (de_DE) ]
jnxd
Post by jnxd »
uwestoehr wrote: Tue Apr 12, 2022 3:50 am It fails for me. This is what I get as result when I recompute the whole file: FreeCAD_hfjDhan66W.png
Note that you are still using master. Please try https://github.com/wwmayer/FreeCAD/tree/issue_6641.
jnxd wrote: Tue Apr 12, 2022 3:23 am @wmayer are you waiting for something to merge this branch?
Well, I didn't want to merge it without other people having tested it. So, if it's OK I will remove the handling with the CompSolid and just always do the boolean operation at the very end.
I will work on it later today...
uwestoehr
Post by uwestoehr »
jnxd wrote: Tue Apr 12, 2022 3:55 am Note that you are still using master. Please try https://github.com/wwmayer/FreeCAD/tree/issue_6641.
Ah, I wondered why GitHub desktop did not offer me this PR and first now I see it is not a PR in FC but in Werner's FC.
However, I cannot test today.
@Werner, for me it is easier to have a PR to FC directly. I check the pending PRs regularly and are this way I am informed and can test.
uwestoehr
Post by uwestoehr »
wmayer wrote: Tue Apr 12, 2022 8:58 am Well, I didn't want to merge it without other people having tested it. So, if it's OK I will remove the handling with the CompSolid and just always do the boolean operation at the very end.
As I wrote yesterday, the regression is only in Loft and Sweep. These objects have been changed in 0.20 to support single vertices as section. This seems to cause the regression with the transformation.
In your PR I see you use CompSolid. Does this means only with a CompSolid, the single-vertex lofts can be handled?
I applied your PR now manually and will report back my testing results.
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Tue Apr 12, 2022 10:31 am I applied your PR now manually and will report back my testing results.
It works well - all these testcases work now: https://forum.freecadweb.org/viewtopic. ... 77#p587977
And also single-vertex loft sections work in transformations, here an example:
Kappe50-jeno-pattern-loft-vertex.FCStd
(619.82 KiB) Downloaded 36 times
No, I have copied the CompSolid stuff from jnxd's branch because using a plain compound doesn't work correctly. But as said above it's not needed and we can just do a single boolean operation at the end.
jnxd
Post by jnxd »
wmayer wrote: Tue Apr 12, 2022 8:58 am I will work on it later today...
I was planning on making a PR into your branch for supporting both fuse and cut tool shapes in the same pattern, similar to https://github.com/FreeCAD/FreeCAD/pull ... d8c66b3b4e. Can do that after you've made your changes.
[EDIT] Made the PR: https://github.com/wwmayer/FreeCAD/pull/4. It shouldn't be too difficult to adapt it to the overlay only version.
jnxd wrote: Tue Apr 12, 2022 12:52 pm
git commit 5ab7d17f67
Now it's your turn.
jnxd
Post by jnxd »
wmayer wrote: Tue Apr 12, 2022 2:34 pm git commit 5ab7d17f67
Now it's your turn.
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
You pushed almost the same time I made a PR.
