0.20 bug/regression Array Pattern issue #6641
user1234
Post by user1234 »
Hello!
There is a bug/regression, source: https://forum.freecadweb.org/viewtopic.php?t=67116
where: git commit 03da9d3501c6b596ad1828b99cb8d923cea56485
Open the attachment and recompute. The pattern (also on mirrors) will not performed correctly (pattern add). Note there is already a bug fixed, which set always the occurrences to 3, i do not mean this bug).
before:
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.24415 (Git)
Build type: Unknown
Branch: (no branch, bisect started on master)
Hash: 89b8e81d5c3b11572a0288720d0b4145d2ec2a7e
Python version: 3.9.2
Qt version: 5.15.2
after:
Version: 0.20.24416 (Git)
Build type: Unknown
Hash: 03da9d3501c6b596ad1828b99cb8d923cea56485
Qt version: 5.15.2
Greetings
user1234
Kappe50-jeno.FCStd
(215.94 KiB) Downloaded 77 times
Re: 0.20 bug/regression Array Pattern
For testing it may be convenient to use this simplified version (linked from the other discussion). It is freed from all know coincidence stuff.
Kappe50_cb.FCStd
user1234
Post by user1234 »
chrisb wrote: Tue Mar 15, 2022 6:08 pm For testing it may be convenient to use this simplified version (linked from the other discussion).
It is not big and has also radius on it. I had a case, where it does sometimes work. So i think that is really a good/better sanity check test case.
Greetings
user1234
Interestingly, if you change the Overlap property to Overlap mode the second instance works but the third (and following if set to a higher number) doesn't. My example is based on the minimal one posted by chrisb but the same happens with the other
Kappe50_aia.FCStd
(22.96 KiB) Downloaded 65 times
uwestoehr
Post by uwestoehr »
Thanks for the report. Here is the issue: https://github.com/FreeCAD/FreeCAD/issues/6641
user1234
Post by user1234 »
Thanks!
Greetings
user1234
jnxd
Post by jnxd »
user1234 wrote: Tue Mar 15, 2022 5:15 pm
Where is this fixed?
user1234
Post by user1234 »
jnxd wrote: Thu Mar 24, 2022 3:37 pm
user1234 wrote: Tue Mar 15, 2022 5:15 pm Note there is already a bug fixed, which set always the occurrences to 3, i do not mean this bug).
When you mean the bug with the 3 occurrences? Here is the link to the bug + bugfixes (i am a little bit in a hurry, if you need something tested, i can a test it, but not asap).
https://forum.freecadweb.org/viewtopic. ... 1&start=10
Greetings
user1234
jnxd
Post by jnxd »
Just looking at the behavior and the text of the commit:
- Use fuzzy fuse/cut method with tolerance Precision::Confusion()
This one change seems to be the culprit.
EDIT: I should just clarify it's purely my speculation.
jnxd
Post by jnxd »
user1234 wrote: Thu Mar 24, 2022 3:56 pm When you mean the bug with the 3 occurrences? Here is the link to the bug + bugfixes (i am a little bit in a hurry, if you need something tested, i can a test it, but not asap).
Thanks.
