Custom thread in hole feature
Re: Custom thread in hole feature
TechDraw supports cosmetic threads.
I wasn't talking about creating 2D drawings
I am after cosmetic representation in 3D - clearly not available yet...
thank you
I also think it would be a great addition to have diameter and pitch exposed . Would it be possible in a future release or is it extremely difficult to implement?chrisb wrote: ↑Thu Mar 03, 2022 5:16 pm It's not always possible to follow one of the norms. So I think it would make a good feature request to have diameter and pitch be exposed to the properties. There could beFor completely customized threads I would as well recommend the helix, because I think it's not worth exposing all angles and radii as well.
- A special entry in the list where these can be added.
- The selected values are only initial preset values.
I don't think that it should be too difficult. I had a look at the code and wondered, why there are json tables containing the thread dimensions as well as arrays in the source code which contain the same or similar data.acominelli wrote: ↑Mon Mar 07, 2022 11:15 am I also think it would be a great addition to have diameter and pitch exposed . Would it be possible in a future release or is it extremely difficult to implement?
Can you please write a feature request in the tracker?
I added feature request #6533 <Expose custom pitch and diameter of threaded hole>
Thanks, here is the link for convenience: issue #6533
You can easily create it with the issue-tag.
- adrianinsaval
