when you use the PartDesign_Hole, some part of the dialog are stuck, red rectangle in the screenshot below:
I don't find "Custom thread" for translation on Crowdin.
following a discussion on the French forum, can you double check the function associated to Hole depth/Dimension/Tapped (DIN76) in front of Thread depth? It seems it's more corresponding to Full thread/Partial thread/DIN76.
hole tool and translation
Re: hole tool and translation
an other point, I want to translate Dimension. on the pic below, there are two Dimensions.
the problem, I want to translate the second one by something different from the first one. on Crowdin there is only one Dimension.
- Capture du 2022-02-23 23-06-55.png (21.22 KiB) Viewed 2443 times
- adrianinsaval
out of curiosity, why different translations?
you are right to ask.
the first translation in French gives Dimension but the second one would be Filetage partiel.
to go even further, the three options are:
English --> French --> English
Hole Depth --> Filetage total --> Full thread
Dimension --> Filetage partiel --> Partial thread
Tapped (DIN76) --> DIN76 --> Tapped (DIN76)
the last column would be the translation of the French guy's demand back to English. I have doubled check with him pointing out that it is not a translation but a radical change and function and he confirmed and nobody complained.
for this topic, I am giving a help to the translation on Crowdin and am not a end user.
- adrianinsaval
That doesn't make much sense to me Sounds like he wants a change of how the tool works, not just a change on how it is translated, that would have to be made as justified feature proposal, better if with a PR since it's possible the devs are not interested in doing such a change.
Vincent B, give a look to this thread. it's the limit of what I can do and ping me on the French forum about the translation.Vincent B wrote:ping
- adrianinsaval
that doesn't work if you don't include the user_id
Like this:
[quote="Vincent B" user_id=5772]
[/quote]
Vincent B answered me on the French forum that we don't need to use wording corresponding to different functions. We keep what we have.
so on this panel, the only thing at the end of day which is problematic: I don't find the wording "Custom Tread" on Crowdin.
