I can't create a threaded hole with the 'reverse' option checked. I get this error:
OS: macOS 10.16
Version: 0.20.27078 (Git)
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
I've attached a sample file that reproduces the issue. Just try to make the hole 'reversed'Reverse hole with thread gives error
- 20-hole.FCStd.zip
- (904.73 KiB) Downloaded 48 times
Re: Reverse hole with thread gives error
Meaning what exactly?
FCStd files are already zip files. You are giving more work for the forum helpers.
So ultimately we end up at https://forum.freecadweb.org/viewtopic.php?p=538546, which says it is confirmed, but I can't find an entry in the bug tracker for it (I searched for threaded and reverse).
The file was too large to upload unless I compressed it. Not sure why there's not a lot in it AFAIK.Shalmeneser wrote: ↑Mon Jan 31, 2022 8:57 pm FCStd files are already zip files. You are giving more work for the forum helpers.
