Supporting point sections in loft (and maybe sweep)
jnxd
Post by jnxd »
Starting a forum thread to discuss PR #5170, which addresses issue #4607.
As mentioned in the PR, the BRepOffsetAPI_ThruSections method that forms the crux of loft supports the first and the last sections to be vertices instead of wires.
My plan of action is as follows:
  1. Allow points of 3D objects to be used as "last section" for loft: [DONE] this was straightforward since we already only take one subelement of the solid (a face, see these lines for reference). I just had to skip making the end face when it is a point.
  2. Allow points of 3D objects to be used as "profile" for loft: [ETA: DONE] this should be just as straightforward, just that it is handled differently and uses a method from the superclass ProfileBased::getProfileWires() which I might have to work around.
  3. Allow points from a sketch to be used for profile and/or last section: [ETA: DONE] needs some changes picking a vertex instead of the entire sketch.
  4. Ensure the loft can be created in both dialog and selection based flows while mixing and matching point sections: [ETA until the bugs stop coming or I get tired :)]
  5. Repeat the above steps for sweep: [ETA: maybe 20 Nov?]
Re: Supporting point sections in loft (and maybe sweep)
did you take a look at my example file on github? (attached here too) we can have sketches with a single point visible outside sketcher, after creating a point they can be toggled to defining geometry (this was introduced late in 0.19 dev cycle IIRC). Selecting a sketch that has a single point should be supported too.
sketchPointVisible.FCStd
(7.37 KiB) Downloaded 56 times
jnxd
Post by jnxd »
adrianinsaval wrote: Sat Nov 13, 2021 2:46 am did you take a look at my example file on github? (attached here too) we can have sketches with a single point visible outside sketcher, after creating a point they can be toggled to defining geometry (this was introduced late in 0.19 dev cycle IIRC). Selecting a sketch that has a single point should be supported too.
I did check it recently, but forgot to mention. I can see that it is visible only when set as a reference vertex. I do not know what implications it'll have on making the loft, but I'll get to it in due time.
