BUG! in Shape.isInside
ebrahim raeyat
Post by ebrahim raeyat »
to produce:
l = Part.Line(App.Vector(0, 0, 0), App.Vector(1, 0, 0))
e = Part.Edge(l)
p = App.Vector(2, 0, 0)
e.isInside(p, .1, True)
It must be False, but it is True. Thanks.
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
ickby
Re: BUG! in Shape.isInside
Post by ickby »
It is not a bug. A part line is a geometric object describing a line, hence is of infinite length. The two points you give to the constructor are two points it oaases through. Hence the edge you created like this is also infinite, and hence the point you check for is on the edge. You can see that the edge is like this by checking its length and it's vertexes (it hasn't any)
To make a finite edge you need to either pass the lines parametric coordinate range you want to use to the constructor Part.Edge(l, 0, 1) or use Part.LineSegment, which is a finite geometric entity by default.
ebrahim raeyat
ickby wrote: Sat Oct 23, 2021 4:25 am It is not a bug. A part line is a geometric object describing a line, hence is of infinite length. The two points you give to the constructor are two points it oaases through. Hence the edge you created like this is also infinite, and hence the point you check for is on the edge. You can see that the edge is like this by checking its length and it's vertexes (it hasn't any)
Thanks, but it does not matter what is the point or finite or infinite, it gives me True in all cases, can you please test it?
>>> import Part
>>> l = Part.LineSegment(App.Vector(0, 0, 0), App.Vector(1, 0, 0))
>>> e = Part.Edge(l)
True
>>> p = App.Vector(2, 1, 0)
True
ickby
Post by ickby »
Ah ok i only checked the initial example... That is strange. I'm not at my pc for a few days, so unfortunately cannot dig for the reason.
But maybe the problem lies also with the edge itself: I think a edge cannot be infinite by definition, and the fact that it has no vertexes may hint to an invalid edge. Maybe that is something to check.
Internally the class BRepClass3d_SolidClassifier is used.
When looking at the class interface it accepts everywhere a TopoDS_Shape and doesn't enforce a TopoDS_Solid as one would assume according to the class name.
Doing some tests it works as expected for:
solids
box=Part.makeBox(1,1,1)
box.isInside(App.Vector(1,1,1), 0.01, True) # => True (OK)
box.isInside(App.Vector(1,1,1.1), 0.01, True) # => False (OK)
and faces
face = Part.Face(Part.Plane())
face.isInside(App.Vector(0,0,0), 0.01, True) # => True (OK)
face.isInside(App.Vector(0,0,0.1), 0.01, True) # => False (OK)
but not for edges or vertexes. So, I am not sure for which shape types it is supposed to work.
ebrahim raeyat
wmayer wrote: Sat Oct 23, 2021 2:39 pm git commit 398381c16e
Thanks wmayer.
MRx
Post by MRx »
seems like there's another bug here.
isInside returns true for both the inside and the outside Vertex.
>>> Gui.Selection.getSelectionEx()[0].SubObjects[0].isInside(FreeCAD.Vector(213.546,-27.3265,-3.3), 0.005, True)
True <<-- should be false
OS: macOS 10.15
Version: 0.20.26549 (Git)
Hash: 92a8e0e3d8f3845e5007f95f4c94bf1c83f50ff6
Python version: 3.9.0
Qt version: 5.15.2
OCC version: 7.5.0
Locale: English/Germany (en_DE)
isInsideBug.FCStd
(163.76 KiB) Downloaded 55 times
