Feature: offset tool in sketcher
db2000
Re: Feature: offset tool in sketcher
Post by db2000 »
Thanks! that makes sense.
That also explains why it worked in the linkstage3 branch but not the main branch.
I'll use your approach of replacing external geometry items when using the main branch version
I appreciate the explanation
paddle
Post by paddle »
Sketcher offset tool is currently on the wait list to be reviewed by Abdullah.
If you want to see how it will work : https://www.youtube.com/watch?v=CffrWKoB2-I
db2000
Post by db2000 »
Thanks, yes I'm definitely looking forward to this being available!
jskalza
Post by jskalza »
I'm fairly new to Freecad and stumbled upon this macro for an Offset capability.
When I run the macro I don't get a dialog requesting the offset value. Instead I get a dotted line which I can drag around. Am I doing something wrong or missing a dependency?
NewJoker
Post by NewJoker »
jskalza wrote: Tue Oct 31, 2023 1:00 am When I run the macro I don't get a dialog requesting the offset value. Instead I get a dotted line which I can drag around. Am I doing something wrong or missing a dependency?
That's how it works. You have to drag the line, click somewhere and then you can add a dimension constraint to one of the blue construction lines to specify the offset value.
Fortunately, paddle's offset tool will be available soon.
