Feature: offset tool in sketcher
Piero69
Re: Feature: offset tool in sketcher
Post by Piero69 »
I too get this error ...
some help?
skopjanecot wrote: Sun Jan 31, 2021 10:25 pm I'm getting the following error when trying to use the macro:
23:23:02  <class 'IndentationError'>: ('expected an indented block', ('/home/___________/.FreeCAD/Macro/SketcherOffset.FCMacro', 28, 1, '""" \n  read selected items and show the offset distance\n""" \n'))
Would just love to have this one work for me. Constraining every little corner for tolerance just destroys my little soul :)
Please attach a preferably simple sketch, so edi can have a look at it.
skopjanecot
Post by skopjanecot »
chrisb wrote: Mon Feb 01, 2021 10:00 am Please attach a preferably simple sketch, so edi can have a look at it.
I get this error when trying to offset a simple rectangle or a line. Not sure a sketch is necessary.
I can confirm:
- Select a line
- call the macro
-> The error shows before even the Popups shows up asking for the offset.
I guess this error is a result of Abdullah's recent Sketcher changes
edi wrote: ping
chrisb wrote: Tue Feb 02, 2021 10:52 am I guess this error is a result of Abdullah's recent Sketcher changes
I am unsure about this: I checked an older version of the macro, when it still was called OffsetInSketcher.py and that works.
skopjanecot
chrisb wrote: Tue Feb 02, 2021 10:56 am
Just checked the older version as well and it works fine. I will use that one until things are figured out. Unfortunately I cannot help more then test the updates :)
edi
Post by edi »
Thank you everybody for your posts in the last days. I have fixed the bug and will try to initiate updating the source in master-github in the next days.
Please use meanwhile the source published in this thread.
What happened ?
The original macro includes many "green" comments (# comment). But macros published in the master must have only "white" comments (''' comment'''). I do not know why.
When changing the comments from one kind to the other, python-syntax errors (indentation errors) occured. And nobody tested.
edi wrote: Wed Feb 03, 2021 8:50 am But macros published in the master must have only "white" comments (''' comment'''). I do not know why.
Other macros installed via AddonManager have "# ... " comments. You may ask in the Python subforum about how to use them.
edi
Post by edi »
Source in master-github
https://github.com/FreeCAD/FreeCAD-macr ... et.FCMacro
has been updated. Hope it's now without issues.
Works again, thanks. It seems that at least some of the redundancies could be avoided. I will have a closer look and report back.
