FWIW, I am able to reproduce the issue in the Python console.
Thread 1 "FreeCAD" received signal SIGSEGV, Segmentation fault.
0x0000000000000521 in ?? ()
(gdb) bt full
#0 0x0000000000000521 in ?? ()
No symbol table info available.
#1 0x00007f1c0c344aa8 in Import::Module::importer (this=0x562395feb760, args=..., kwds=...)
at /mnt/source/src/Mod/Import/App/AppImportPy.cpp:256
tuple = {<Py::SeqBase<Py::Object>> = {<Py::Object> = {_vptr.Object = 0x7f1c8c66a9a0 <vtable for Py::Tuple+16>,
p = 0x7f1c6115cdc0}, <No data fields>}, <No data fields>}
colors =
{<App::PropertyListsT<App::Color, std::vector<App::Color, std::allocator<App::Color> >, App::PropertyLists>> = {<App::PropertyLists> = {<App::Property> = {<Base::Persistence> = {<Base::BaseClass> = {_vptr.BaseClass = 0x7ffc3ffc2894,
static classTypeId = {_vptr.Type = 0x7f1c893481b0 <vtable for Base::Type+16>, index = 1,
static typemap = <optimized out>,
static typedata = {<std::_Vector_base<Base::TypeData*, std::allocator<Base::TypeData*> >> = {
_M_impl = {<std::allocator<Base::TypeData*>> = {<__gnu_cxx::new_allocator<Base::TypeData*>> = {<No data fields>}, <No data fields>}, _M_start = 0x5623960001d0, _M_finish = 0x562396000e10,
_M_end_of_storage = 0x5623960011d0}}, <No data fields>},
static loadModuleSet = <optimized out>}}, static classTypeId = {
_vptr.Type = 0x7f1c893481b0 <vtable for Base::Type+16>, index = 4,
_vptr.Type = 0x7f1c893481b0 <vtable for Base::Type+16>, index = 7, static typemap = <optimized out>,
static loadModuleSet = <optimized out>}, StatusBits = std::bitset = {[5] = 1, [6] = 1, [8] = 1,
[11] = 1, [13] = 1, [18] = 1, [19] = 1, [20] = 1, [21] = 1, [22] = 1, [23] = 1, [24] = 1, [25] = 1,
[26] = 1, [27] = 1, [28] = 1, [29] = 1, [34] = 1, [35] = 1, [36] = 1, [37] = 1, [38] = 1, [39] = 1,
[40] = 1, [41] = 1, [42] = 1, [43] = 1, [44] = 1, [45] = 1, [46] = 1}, father = 0x562393e341b0,
myName = 0x4d <error: Cannot access memory at address 0x4d>}, <App::PropertyListsBase> = {
_vptr.PropertyListsBase = 0x3ffc2ab0, _touchList = std::set with 140721381976576 elements
<error reading variable: Cannot access memory at address 0x70756f72672078>}, static classTypeId = {
_vptr.Type = 0x7f1c893481b0 <vtable for Base::Type+16>, index = 9, static typemap = <optimized out>,
---Type <return> to continue, or q <return> to quit---
static loadModuleSet = <optimized out>}}, <App::AtomicPropertyChangeInterface<App::PropertyListsT<App::Color, std::vector<App::Color, std::allocator<App::Color> >, App::PropertyLists> >> = {signalCounter = 0,
hasChanged = false}, _lValueList = std::vector of length 0, capacity 8795086373538 = {
<error reading variable>
it = @0x562396af9180: {first = 0x5623960bab90, second = std::vector of length 1, capacity 1 = {{
r = 0.800000012, g = 0.800000012, b = 0.800000012, a = 0}}}
__for_range = std::map with 6 elements = {[0x5623960bab90] = std::vector of length 1, capacity 1 = {{
r = 0.800000012, g = 0.800000012, b = 0.800000012, a = 0}},
[0x562396c77050] = std::vector of length 1, capacity 1 = {{r = 0.800000012, g = 0.800000012,
b = 0.800000012, a = 0}}, [0x562396cb1a10] = std::vector of length 1, capacity 1 = {{r = 0.800000012,
g = 0.800000012, b = 0.800000012, a = 0}}, [0x562396d2c810] = std::vector of length 1, capacity 1 = {{
[0x562396d31bc0] = std::vector of length 1, capacity 1 = {{r = 0.800000012, g = 0.800000012,
b = 0.800000012, a = 0}}, [0x5623974470b0] = std::vector of length 0, capacity 0}
__for_begin =
{first = 0x5623960bab90, second = std::vector of length 1, capacity 1 = {{r = 0.800000012, g = 0.800000012, b = 0.800000012, a = 0}}}
__for_end =
{first = 0x6, second = std::vector of length -45419966, capacity 60049414153 = {{r = -3.63499999e-32, g = 4.5598252e-41, b = -3.63501351e-32, a = 4.5598252e-41}, {r = -3.63498412e-32, g = 4.5598252e-41, b = -3.63864226e-32, a = 4.5598252e-41}, {r = -3.7297848e-32, g = 4.5598252e-41, b = -3.72970252e-32, a = 4.5598252e-41}, {r = -3.63864755e-32, g = 4.5598252e-41, b = -3.6452503e-32, a = 4.5598252e-41}, {r = -3.63484365e-32, g = 4.5598252e-41, b = 0, a = 0}, {r = -1.77735874e-31, g = 4.5598252e-41, b = -3.727991e-32, a = 4.5598252e-41}, {r = -3.72800451e-32, g = 4.5598252e-41, b = -3.63457681e-32, a = 4.5598252e-41}, {r = -3.63854175e-32, g = 4.5598252e-41, b = -3.63456564e-32, a = 4.5598252e-41}, {r = -3.72981242e-32, g = 4.5598252e-41, b = -3.63470788e-32, a = 4.5598252e-41}, {r = -3.72985592e-32, g = 4.5598252e-41, b = -3.72989588e-32, a = 4.5598252e-41}, {r = 0, g = 0, b = -1.77736156e-31, a = 4.5598252e-41}, {r = -3.63459268e-32, g = 4.5598252e-41, b = -3.6346062e-32, a = 4.5598252e-41}, {r = -3.72993468e-32, g = 4.5598252e-41, b = -3.63854175e-32, a = 4.5598252e-41}, {r = -3.72995055e-32, g = 4.5598252e-41, b = -3.72981242e-32, a = 4.5598252e-41}, {r = -3.72996171e-32, g = 4.5598252e-41, b = -3.72985592e-32, a = 4.5598252e-41}, {r = -3.72989588e-32, g = 4.5598252e-41, b = 0, a = 0}, {r = -1.77736439e-31, g = 4.5598252e-41, b = -3.72801568e-32, a = 4.5598252e-41}, {r = -3.7280292e-32, g = 4.5598252e-41, b = -3.63451451e-32, a = 4.5598252e-41}, {r = 0, g = 0, b = -1.77736721e-31, a = 4.5598252e-41}, {r = -3.72804037e-32, g = 4.5598252e-41, b = -3.72805389e-32, a = 4.5598252e-41}, {r = -3.63437698e-32, g = 4.5598252e-41, b = -3.63850414e-32, a = 4.5598252e-41}, {r = -3.63439285e-32, g = 4.5598252e-41, b = -3.72998816e-32, a = 4.5598252e-41}, {r = -3.63446102e-32, g = 4.5598252e-41, b = -3.73003165e-32, a = 4.5598252e-41}, {r = -3.73007162e-32, g = 4.5598252e-41, b = 0, a = 0}, {r = -1.77737003e-31, g = 4.5598252e-41, b = -3.63440401e-32, a = 4.5598252e-41}, {r = -3.63441753e-32, g = 4.5598252e-41, b = -3.73011041e-32, a = 4.5598252e-41}, {r = -3.63850414e-32, g = 4.5598252e-41, b = -3.73012628e-32, a = 4.5598252e-41}, {r = -3.72998816e-32, g = 4.5598252e-41, b = -3.73013745e-32, a = 4.5598252e-41}, {r = -3.73003165e-32, g = 4.5598252e-41, b = -3.73007162e-32, a = 4.5598252e-41}, {r = 0, g = 0, b = -1.77737285e-31, a = 4.5598252e-41}, {r = -3.72806505---Type <return> to continue, or q <return> to quit---
e-32, g = 4.5598252e-41, b = -3.72807857e-32, a = 4.5598252e-41}, {r = -3.63432584e-32, g = 4.5598252e-41, b = 0, a = 0}, {r = -1.77737567e-31, g = 4.5598252e-41, b = -3.63488244e-32, a = 4.5598252e-41}, {r = -3.63489596e-32, g = 4.5598252e-41, b = -3.73014744e-32, a = 4.5598252e-41}, {r = -3.63864226e-32, g = 4.5598252e-41, b = -3.7297848e-32, a = 4.5598252e-41}, {r = -3.72970252e-32, g = 4.5598252e-41, b = -3.63864755e-32, a = 4.5598252e-41}, {r = -3.6452503e-32, g = 4.5598252e-41, b = -3.72974601e-32, a = 4.5598252e-41}, {r = 0, g = 0, b = -1.77738413e-31, a = 4.5598252e-41}, {r = -3.6340978e-32, g = 4.5598252e-41, b = -3.63411132e-32, a = 4.5598252e-41}, {r = -3.63413306e-32, g = 4.5598252e-41, b = 3.47522019e-43, a = 0}, {r = 0, g = 0, b = -1.77738601e-31, a = 4.5598252e-41}, {r = -3.63387916e-32, g = 4.5598252e-41, b = -3.63391207e-32, a = 4.5598252e-41}, {r = -nan(0x7fff08), g = -nan(0x7fffff), b = -nan(0x7fff08), a = -nan(0x7fffff)}, {r = -1.77738601e-31, g = 4.5598252e-41, b = -3.63390913e-32, a = 4.5598252e-41}, {r = -3.63392324e-32, g = 4.5598252e-41, b = -1.77703713e-31, a = 4.5598252e-41}, {r = -1.77705217e-31, g = 4.5598252e-41, b = -1.77706158e-31, a = 4.5598252e-41}, {r = -1.77706628e-31, g = 4.5598252e-41, b = -1.77705688e-31, a = 4.5598252e-41}, {r = -1.77704183e-31, g = 4.5598252e-41, b = 3.47522019e-43, a = 0}, {r = 0, g = 0, b = -7.40958558e-37, a = 4.5598252e-41}, {r = 0, g = 0, b = 0, a = 0}, {r = -nan(0x7fff08), g = -nan(0x7fffff), b = -nan(0x7fff08), a = -nan(0x7fffff)}, {r = -7.40958558e-37, g = 4.5598252e-41, b = 0, a = 0}, {r = 0, g = 0, b = 3.47522019e-43, a = 0}, {r = 0, g = 0, b = -7.41216128e-37, a = 4.5598252e-41}, {r = 0, g = 0, b = 0, a = 0}, {r = -nan(0x7fff08), g = -nan(0x7fffff), b = -nan(0x7fff08), a = -nan(0x7fffff)}, {r = -7.41216128e-37, g = 4.5598252e-41, b = 0, a = 0}, {r = 0, g = 0, b = 0, a = 0}, {r = -1.77738884e-31, g = 4.5598252e-41, b = -3.63344246e-32, a = 4.5598252e-41}, {r = -3.63346068e-32, g = 4.5598252e-41, b = -3.63347185e-32, a = 4.5598252e-41}, {r = 0, g = 0, b = -1.77739166e-31, a = 4.5598252e-41}, {r = 0, g = 0, b = 0, a = 0}, {r = -6.0422519e-37, g = 4.5598252e-41, b = -6.0422519e-37, a = 4.5598252e-41}, {r = -6.0422519e-37, g = 4.5598252e-41, b = -6.0422519e-37, a = 4.5598252e-41}, {r = 0, g = 0, b = -1.77739354e-31, a = 4.5598252e-41}, {r = 0, g = 0, b = 0, a = 0}, {r = -6.0422519e-37, g = 4.5598252e-41, b = 0, a = 0}, {r = -1.77739636e-31, g = 4.5598252e-41, b = -3.72242268e-32, a = 4.5598252e-41}, {r = -3.7224362e-32, g = 4.5598252e-41, b = -6.08042103e-37, a = 4.5598252e-41}, {r = 0, g = 0, b = -1.777402e-31, a = 4.5598252e-41}, {r = 0, g = 0, b = 0, a = 0}, {r = -6.0422519e-37, g = 4.5598252e-41, b = -3.63103857e-32, a = 4.5598252e-41}, {r = -6.0422519e-37, g = 4.5598252e-41, b = -6.0422519e-37, a = 4.5598252e-41}, {r = -6.0422519e-37, g = 4.5598252e-41, b = 0, a = 0}, {r = -1.7774067e-31, g = 4.5598252e-41, b = -6.0422519e-37, a = 4.5598252e-41}, {r = -6.0422519e-37, g = 4.5598252e-41, b = 0, a = 0}, {r = 0, g = 0, b = 0, a = 0}, {r = -1.77740858e-31, g = 4.5598252e-41, b = -6.0422519e-37, a = 4.5598252e-41}, {r = -6.0422519e-37, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83312045e-32, g = 4.5598252e-41, b = -1.77711048e-31, a = 4.5598252e-41}, {r = -7.40261182e-37, g = 4.5598252e-41, b = -6.83315807e-32, a = 4.5598252e-41}, {r = 0, g = 2.80259693e-45, b = -1.77711706e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -1.7774067e-31, a = 4.5598252e-41}, {r = -nan(0x7fe803), g = -nan(0x7fffff), b = -7.40261182e-37, a = 4.5598252e-41}, {r = -6.83321449e-32, g = 4.5598252e-41, b = 0, a = 2.80259693e-45}, {r = -1.77739636e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -1.77740858e-31, g = 4.5598252e-41, b = 5.74252111e-42, a = 0}, {r = -7.40111949e-37, g = 4.5598252e-41, b = -6.83327091e-32, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83336495e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83351542e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40111949e-37, g = 4.5598252e-41, b = -6.83368469e-32, a = 4.5598252e-41}, {r = -7.40111949e-37, g = 4.5598252e-41, b = -6.83377873e-32, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83385396e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83398561e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40111949e-37, g = 4.5598252e-41, b = -6.83413608e-32, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83421131e-32, a---Type <return> to continue, or q <return> to quit---
= 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83434296e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40111949e-37, g = 4.5598252e-41, b = -6.83449343e-32, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83458747e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83468151e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83475674e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83481316e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83486959e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83500124e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.8351329e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83524574e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83535859e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83550905e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83565952e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83579117e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83594164e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.8360921e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83624256e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83629899e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83644945e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83659991e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83673157e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83686322e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83701369e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83714534e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.837277e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83731461e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83744627e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83757792e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83769077e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83780362e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83793527e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83806693e-32, g = 4.5598252e-41, b = -1.777402e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83819859e-32, a = 4.5598252e-41}, {r = -1.777402e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83833024e-32, g = 4.5598252e-41, b = -1.77739166e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83844309e-32, a = 4.5598252e-41}, {r = -1.77739166e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83853713e-32, g = 4.5598252e-41, b = -1.77739166e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83863117e-32, a = 4.5598252e-41}, {r = -1.77739166e-31, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83874401e-32, g = 4.5598252e-41, b = -1.7773437e-31, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.84030507e----Type <return> to continue, or q <return> to quit---
32, a = 4.5598252e-41}, {r = -2.71708804e-36, g = 4.5598252e-41, b = -7.40261182e-37, a = 4.5598252e-41}, {r = -6.83878163e-32, g = 4.5598252e-41, b = 0, a = 2.80259693e-45}, {r = -1.77739354e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -1.77741046e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -7.40261182e-37, g = 4.5598252e-41, b = -6.83889448e-32, a = 4.5598252e-41}, {r = 0, g = 2.80259693e-45, b = -1.77739354e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -1.77741235e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -7.40261182e-37, a = 4.5598252e-41}, {r = -6.83898852e-32, g = 4.5598252e-41, b = 0, a = 2.80259693e-45}, {r = -1.77739354e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -1.77741423e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -7.40261182e-37, g = 4.5598252e-41, b = -6.83908256e-32, a = 4.5598252e-41}, {r = 0, g = 2.80259693e-45, b = -1.77739354e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -1.77741611e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -7.40261182e-37, a = 4.5598252e-41}, {r = -6.8391954e-32, g = 4.5598252e-41, b = 0, a = 2.80259693e-45}, {r = -1.77739354e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -1.77741799e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -7.40261182e-37, g = 4.5598252e-41, b = -6.83928944e-32, a = 4.5598252e-41}, {r = 0, g = 2.80259693e-45, b = -1.77739354e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -1.77741987e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -7.40261182e-37, a = 4.5598252e-41}, {r = -6.83938348e-32, g = 4.5598252e-41, b = 0, a = 2.80259693e-45}, {r = -1.77739354e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -1.77742175e-31, g = 4.5598252e-41, b = 2.80259693e-45, a = 0}, {r = -7.40261182e-37, g = 4.5598252e-41, b = -6.83947752e-32, a = 4.5598252e-41}, {r = 0, g = 8.40779079e-45, b = -1.77731831e-31, a = 4.5598252e-41}, {r = 2.80259693e-45, g = 0, b = -1.77732019e-31, a = 4.5598252e-41}, {r = 2.87266185e-42, g = 0, b = -1.77732583e-31, a = 4.5598252e-41}, {r = 5.74252111e-42, g = 0, b = -1.77731643e-31, a = 4.5598252e-41}, {r = 8.61238036e-42, g = 0, b = -1.77732395e-31, a = 4.5598252e-41}, {r = 1.14822396e-41, g = 0, b = -1.77732207e-31, a = 4.5598252e-41}, {r = 1.43520989e-41, g = 0, b = -7.40111949e-37, a = 4.5598252e-41}, {r = -6.83949633e-32, g = 4.5598252e-41, b = -7.40111949e-37, a = 4.5598252e-41}, {r = -6.83951514e-32, g = 4.5598252e-41, b = -7.40111949e-37, a = 4.5598252e-41}, {r = -6.83953395e-32, g = 4.5598252e-41, b = -7.40111949e-37, a = 4.5598252e-41}, {r = -6.83955275e-32, g = 4.5598252e-41, b = -7.40111949e-37, a = 4.5598252e-41}, {r = -6.83957156e-32, g = 4.5598252e-41, b = -7.40111949e-37, a = 4.5598252e-41}, {r = -6.83959037e-32, g = 4.5598252e-41, b = -7.40111949e-37, a = 4.5598252e-41}, {r = -6.83960918e-32, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83962799e-32, g = 4.5598252e-41, b = -7.40316786e-37, a = 4.5598252e-41}, {r = -7.40252572e-37, g = 4.5598252e-41, b = -6.83964679e-32, a = 4.5598252e-41}, {r = -7.40511936e-37, g = 4.5598252e-41, b = -7.40252572e-37, a = 4.5598252e-41}, {r = -6.83968441e-32, g = 4.5598252e-41, b = -1.77733899e-31, a = 4.5598252e-41}...}}
list = {<Py::SeqBase<Py::Object>> = {<Py::Object> = {_vptr.Object = 0x7f1c8c66bde8 <vtable for Py::List+16>,
p = 0x7f1c6116fe60}, <No data fields>}, <No data fields>}
file = {FileName = "/mnt/files/Nova_C_Wall.stp"}
pcDoc = 0x562395a74c40
hDoc = {entity = 0x562396af2c60}
hApp = {entity = 0x562396af24b0}
ocaf = {<Import::ImportOCAF2> = {_vptr.ImportOCAF2 = 0x7f1c0c5ee4f0 <vtable for ImportOCAFExt+16>, pDoc = {
entity = 0x562396af2c60}, pDocument = 0x562395a74c40, aShapeTool = {entity = 0x562396af3210},
aColorTool = {entity = 0x562396af3370}, merge = true, default_name = "Nova_C_Wall", useLinkGroup = true,
useBaseName = true, importHidden = true, reduceObjects = true, showProgress = true, expandCompound = true,
mode = 0, filePath = "", myShapes = std::unordered_map with 7 elements = {[{myTShape = {
entity = 0x56239a4f5800}, myLocation = {myItems = {myNode = {entity = 0x0}}},
myOrient = TopAbs_FORWARD}] = {baseName = "Nova C wall", obj = 0x562397304630, propPlacement =
0x562397304e18, faceColor = {r = 0.800000012, g = 0.800000012, b = 0.800000012, a = 0}, edgeColor = {
r = 0.0980392173, g = 0.0980392173, b = 0.0980392173, a = 0}, hasFaceColor = false,
hasEdgeColor = false, free = 0}, [{myTShape = {entity = 0x56239a380290}, myLocation = {myItems = {
myNode = {entity = 0x0}}}, myOrient = TopAbs_FORWARD}] = {
baseName = "Nova C I Nova C w Br straight metal strip", obj = 0x562396d31bc0,
propPlacement = 0x562396d32010, faceColor = {r = 0.800000012, g = 0.800000012, b = 0.800000012,
a = 0}, edgeColor = {r = 0.0980392173, g = 0.0980392173, b = 0.0980392173, a = 0},
hasFaceColor = false, hasEdgeColor = false, free = 1}, [{myTShape = {entity = 0x562399a80ed0},
myLocation = {myItems = {myNode = {entity = 0x0}}}, myOrient = TopAbs_FORWARD}] = {
baseName = "Nova C w Br single slender rib", obj = 0x562396d2c810, propPlacement = 0x562396d2cc60,
faceColor = {r = 0.800000012, g = 0.800000012, b = 0.800000012, a = 0}, edgeColor = {r = 0.0980392173,
g = 0.0980392173, b = 0.0980392173, a = 0}, hasFaceColor = false, hasEdgeColor = false, free = 1}, [{
myTShape = {entity = 0x562396fd9b10}, myLocation = {myItems = {myNode = {entity = 0x0}}},
myOrient = TopAbs_FORWARD}] = {baseName = "Nova C Wall leg part 1", obj = 0x5623960bab90,
propPlacement = 0x5623960bafe0, faceColor = {r = 0.800000012, g = 0.800000012, b = 0.800000012,
hasFaceColor = false, hasEdgeColor = false, free = 0}, [{myTShape = {entity = 0x56239a4f5750},
baseName = "Nova C Wall leg", obj = 0x5623960bb7a0, propPlacement = 0x5623960bbf88, faceColor = {
myTShape = {entity = 0x562399ad46a0}, myLocation = {myItems = {myNode = {entity = 0x0}}},
myOrient = TopAbs_FORWARD}] = {baseName = "Nova C Wall leg part 2", obj = 0x562396cb1a10,
propPlacement = 0x562396cb1e60, faceColor = {r = 0.800000012, g = 0.800000012, b = 0.800000012,
hasFaceColor = false, hasEdgeColor = false, free = 0}, [{myTShape = {entity = 0x562399b6ac70},
baseName = "Nova C w Br single wide rib", obj = 0x562396c77050, propPlacement = 0x562396c774a0,
g = 0.0980392173, b = 0.0980392173, a = 0}, hasFaceColor = false, hasEdgeColor = false, free = 1}},
myNames = std::unordered_map with 22 elements = {[{myLabelNode = 0x562396af4ce0}] = "Link003.1", [{
myLabelNode = 0x562396af4ca8}] = "Link003.0", [{myLabelNode = 0x562396af4ae8}] = "Link002.6", [{
myLabelNode = 0x562396af4ab0}] = "Link002.5", [{myLabelNode = 0x562396af4c38}] = "Link002.12", [{
myLabelNode = 0x562396af4b90}] = "Link002.9", [{myLabelNode = 0x562396af4848}] = "Link.0", [{
myLabelNode = 0x562396af4b58}] = "Link002.8", [{myLabelNode = 0x562396af4810}] = "Solid001", [{
myLabelNode = 0x562396af4bc8}] = "Link002.10", [{myLabelNode = 0x562396af4880}] = "Link.1", [{
myLabelNode = 0x562396af4c00}] = "Link002.11", [{myLabelNode = 0x562396af4b20}] = "Link002.7", [{
myLabelNode = 0x562396af47a0}] = "Solid", [{myLabelNode = 0x562396af46f8}] = "LinkGroup001", [{
myLabelNode = 0x562396af4a78}] = "Link002.4", [{myLabelNode = 0x562396af49d0}] = "Link002.1", [{
myLabelNode = 0x562396af48f0}] = "Link001.0", [{myLabelNode = 0x562396af4a08}] = "Link002.2", [{
myLabelNode = 0x562396af4928}] = "Link001.1", [{myLabelNode = 0x562396af4998}] = "Link002.0", [{
myLabelNode = 0x562396af4a40}] = "Link002.3"},
myCollapsedObjects = std::unordered_map with 0 elements, defaultFaceColor = {r = 0.800000012,
g = 0.800000012, b = 0.800000012, a = 0}, defaultEdgeColor = {r = 0.0980392173, g = 0.0980392173,
b = 0.0980392173, a = 0}, sequencer = 0x0}, partColors = std::map with 6 elements = {
[0x5623960bab90] = std::vector of length 1, capacity 1 = {{r = 0.800000012, g = 0.800000012,
b = 0.800000012, a = 0}}, [0x562396c77050] = std::vector of length 1, capacity 1 = {{r = 0.800000012,
g = 0.800000012, b = 0.800000012, a = 0}}, [0x562396cb1a10] = std::vector of length 1, capacity 1 = {{
[0x562396d2c810] = std::vector of length 1, capacity 1 = {{r = 0.800000012, g = 0.800000012,
b = 0.800000012, a = 0}}, [0x562396d31bc0] = std::vector of length 1, capacity 1 = {{r = 0.800000012,
g = 0.800000012, b = 0.800000012, a = 0}}, [0x5623974470b0] = std::vector of length 0, capacity 0}}
Name = 0x7f1c61133e10 ""
DocName = 0x0
importHidden = 0x7f1c885526f0 <_Py_NoneStruct>
merge = 0x7f1c885526f0 <_Py_NoneStruct>
useLinkGroup = 0x7f1c885526f0 <_Py_NoneStruct>
mode = -1
kwd_list = {0x7f1c0c3b7f0a "name", 0x7f1c0c3b7f0f "docName", 0x7f1c0c3b7f17 "importHidden",
0x7f1c0c3b7f24 "merge", 0x7f1c0c3b7f2a "useLinkGroup", 0x7f1c0c3b7f37 "mode", 0x0}
Utf8Name = "/mnt/files/Nova_C_Wall.stp"
name8bit = "/mnt/files/Nova_C_Wall.stp"
#2 0x00007f1c0c354496 in Py::ExtensionModule<Import::Module>::invoke_method_keyword (this=0x562395feb760,
method_def=0x562395feb8c0, args=..., keywords=...) at /mnt/source/src/CXX/Python3/ExtensionModule.hxx:190
self = 0x562395feb760
meth_def = 0x562395feb8c0
#3 0x00007f1c88fd2f77 in Py::method_keyword_call_handler (_self_and_name_tuple=0x7f1c611c12d0, _args=0x7f1c61111d50,
_keywords=0x0) at /mnt/source/src/CXX/Python3/cxx_extensions.cxx:1591
keywords = {<Py::MapBase<Py::Object>> = {<Py::Object> = {
_vptr.Object = 0x7f1c8c66bd58 <vtable for Py::Dict+16>,
p = 0x7f1c6112db90}, <No data fields>}, <No data fields>}
result = {_vptr.Object = 0x7f1c6111bc80, p = 0xd33c4b686cfff44d}
self_and_name_tuple = {<Py::SeqBase<Py::Object>> = {<Py::Object> = {
p = 0x7f1c611c12d0}, <No data fields>}, <No data fields>}
self_in_cobject = 0x7f1c611c5e10
self_as_void = 0x562395feb760
args = {<Py::SeqBase<Py::Object>> = {<Py::Object> = {_vptr.Object = 0x7f1c8c66a9a0 <vtable for Py::Tuple+16>,
p = 0x7f1c61111d50}, <No data fields>}, <No data fields>}
#4 0x00007f1c880fe753 in _PyMethodDef_RawFastCallKeywords (method=0x562395feb8e0, self=<optimized out>,
args=0x5623945bc198, nargs=1, kwnames=<optimized out>) at ../Objects/call.c:694
kwdict = 0x0
argtuple = 0x7f1c61111d50
meth = 0x7f1c88fd2e21 <Py::method_keyword_call_handler(PyObject*, PyObject*, PyObject*)>
flags = <optimized out>
nkwargs = <optimized out>
result = 0x0
#5 0x00007f1c880fe7d5 in _PyCFunction_FastCallKeywords (func=0x7f1c6805eaf0, args=<optimized out>,
nargs=<optimized out>, kwnames=<optimized out>) at ../Objects/call.c:734
result = <optimized out>
#6 0x00007f1c880d6aa8 in call_function (kwnames=0x0, oparg=1, pp_stack=<synthetic pointer>) at ../Python/ceval.c:4568
tstate = 0x562393c5ffd0
func = <optimized out>
w = <optimized out>
nkwargs = 0
nargs = 1
pfunc = 0x5623945bc190
x = <optimized out>
stack = 0x5623945bc198
#7 _PyEval_EvalFrameDefault (f=<optimized out>, throwflag=<optimized out>) at ../Python/ceval.c:3093
sp = 0x5623945bc1a0
res = <optimized out>
meth = <optimized out>
stack_pointer = 0x5623945bc1a0
next_instr = <optimized out>
opcode = <optimized out>
oparg = 1
why = <optimized out>
fastlocals = <optimized out>
freevars = <optimized out>
retval = 0x0
tstate = <optimized out>
co = <optimized out>
instr_ub = -1
instr_lb = 0
instr_prev = -1
first_instr = <optimized out>
names = <optimized out>
consts = <optimized out>
opcode_targets = {0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d1a1d <_PyEval_EvalFrameDefault+9181>, 0x7f1c880d1a71 <_PyEval_EvalFrameDefault+9265>,
0x7f1c880d1ac4 <_PyEval_EvalFrameDefault+9348>, 0x7f1c880d1d4a <_PyEval_EvalFrameDefault+9994>,
0x7f1c880d1c05 <_PyEval_EvalFrameDefault+9669>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d1c64 <_PyEval_EvalFrameDefault+9764>, 0x7f1c880d1e6d <_PyEval_EvalFrameDefault+10285>,
0x7f1c880d1ef8 <_PyEval_EvalFrameDefault+10424>, 0x7f1c880d1857 <_PyEval_EvalFrameDefault+8727>,
0x7f1c880d18eb <_PyEval_EvalFrameDefault+8875>, 0x7f1c880d1976 <_PyEval_EvalFrameDefault+9014>,
0x7f1c880d03d6 <_PyEval_EvalFrameDefault+3478>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d1510 <_PyEval_EvalFrameDefault+7888>, 0x7f1c880d17b0 <_PyEval_EvalFrameDefault+8560>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d160e <_PyEval_EvalFrameDefault+8142>,
0x7f1c880d16df <_PyEval_EvalFrameDefault+8351>, 0x7f1c880d0fe5 <_PyEval_EvalFrameDefault+6565>,
0x7f1c880d108c <_PyEval_EvalFrameDefault+6732>, 0x7f1c880d1133 <_PyEval_EvalFrameDefault+6899>,
0x7f1c880d11da <_PyEval_EvalFrameDefault+7066>, 0x7f1c880d1281 <_PyEval_EvalFrameDefault+7233>,
0x7f1c880d1328 <_PyEval_EvalFrameDefault+7400>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337> <repeats 20 times>,
0x7f1c880d13cf <_PyEval_EvalFrameDefault+7567>, 0x7f1c880d1488 <_PyEval_EvalFrameDefault+7752>,
0x7f1c880d0ba6 <_PyEval_EvalFrameDefault+5478>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d1d9c <_PyEval_EvalFrameDefault+10076>,
0x7f1c880d1ca3 <_PyEval_EvalFrameDefault+9827>, 0x7f1c880d30c9 <_PyEval_EvalFrameDefault+14985>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d224c <_PyEval_EvalFrameDefault+11276>,
0x7f1c880d32ba <_PyEval_EvalFrameDefault+15482>, 0x7f1c880d3170 <_PyEval_EvalFrameDefault+15152>,
0x7f1c880d3213 <_PyEval_EvalFrameDefault+15315>, 0x7f1c880d0cec <_PyEval_EvalFrameDefault+5804>,
0x7f1c880d3022 <_PyEval_EvalFrameDefault+14818>, 0x7f1c880d2ed4 <_PyEval_EvalFrameDefault+14484>,
0x7f1c880d2f7b <_PyEval_EvalFrameDefault+14651>, 0x7f1c880d2c4a <_PyEval_EvalFrameDefault+13834>,
0x7f1c880d2cf8 <_PyEval_EvalFrameDefault+14008>, 0x7f1c880d2d83 <_PyEval_EvalFrameDefault+14147>,
0x7f1c880d2e28 <_PyEval_EvalFrameDefault+14312>, 0x7f1c880d07f6 <_PyEval_EvalFrameDefault+4534>,
0x7f1c880d085b <_PyEval_EvalFrameDefault+4635>, 0x7f1c880d097d <_PyEval_EvalFrameDefault+4925>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d0a10 <_PyEval_EvalFrameDefault+5072>,
0x7f1c880d2749 <_PyEval_EvalFrameDefault+12553>, 0x7f1c880d27f0 <_PyEval_EvalFrameDefault+12720>,
0x7f1c880d3938 <_PyEval_EvalFrameDefault+17144>, 0x7f1c880d3ba0 <_PyEval_EvalFrameDefault+17760>,
0x7f1c880d1f83 <_PyEval_EvalFrameDefault+10563>, 0x7f1c880d1f8e <_PyEval_EvalFrameDefault+10574>,
0x7f1c880d20cc <_PyEval_EvalFrameDefault+10892>, 0x7f1c880d3b88 <_PyEval_EvalFrameDefault+17736>,
0x7f1c880d3379 <_PyEval_EvalFrameDefault+15673>, 0x7f1c880d35d4 <_PyEval_EvalFrameDefault+16276>,
0x7f1c880d368c <_PyEval_EvalFrameDefault+16460>, 0x7f1c880d36b7 <_PyEval_EvalFrameDefault+16503>,
0x7f1c880d0280 <_PyEval_EvalFrameDefault+3136>, 0x7f1c880d15be <_PyEval_EvalFrameDefault+8062>,
0x7f1c880d0320 <_PyEval_EvalFrameDefault+3296>, 0x7f1c880d1b85 <_PyEval_EvalFrameDefault+9541>,
0x7f1c880d047d <_PyEval_EvalFrameDefault+3645>, 0x7f1c880d056f <_PyEval_EvalFrameDefault+3887>,
0x7f1c880d39df <_PyEval_EvalFrameDefault+17311>, 0x7f1c880d3ad7 <_PyEval_EvalFrameDefault+17559>,
0x7f1c880d05ed <_PyEval_EvalFrameDefault+4013>, 0x7f1c880d075a <_PyEval_EvalFrameDefault+4378>,
0x7f1c880d0687 <_PyEval_EvalFrameDefault+4167>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d06fe <_PyEval_EvalFrameDefault+4286>, 0x7f1c880d218c <_PyEval_EvalFrameDefault+11084>,
0x7f1c880d21f0 <_PyEval_EvalFrameDefault+11184>, 0x7f1c880d444d <_PyEval_EvalFrameDefault+19981>,
0x7f1c880d44ac <_PyEval_EvalFrameDefault+20076>, 0x7f1c880d3f6d <_PyEval_EvalFrameDefault+18733>,
0x7f1c880d4517 <_PyEval_EvalFrameDefault+20183>, 0x7f1c880d4000 <_PyEval_EvalFrameDefault+18880>,
0x7f1c880d402d <_PyEval_EvalFrameDefault+18925>, 0x7f1c880d0c4c <_PyEval_EvalFrameDefault+5644>,
0x7f1c880d4402 <_PyEval_EvalFrameDefault+19906>, 0x7f1c880d42de <_PyEval_EvalFrameDefault+19614>,
0x7f1c880d4370 <_PyEval_EvalFrameDefault+19760>, 0x7f1c880d3d60 <_PyEval_EvalFrameDefault+18208>,
0x7f1c880d3dbe <_PyEval_EvalFrameDefault+18302>, 0x7f1c880d3e69 <_PyEval_EvalFrameDefault+18473>,
0x7f1c880d3f12 <_PyEval_EvalFrameDefault+18642>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d2897 <_PyEval_EvalFrameDefault+12887>,
0x7f1c880d66ae <_PyEval_EvalFrameDefault+28782>, 0x7f1c880cff94 <_PyEval_EvalFrameDefault+2388>,
0x7f1c880cff94 <_PyEval_EvalFrameDefault+2388>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d1b21 <_PyEval_EvalFrameDefault+9441>, 0x7f1c880d2a53 <_PyEval_EvalFrameDefault+13331>,
0x7f1c880d2ac0 <_PyEval_EvalFrameDefault+13440>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d2b42 <_PyEval_EvalFrameDefault+13570>, 0x7f1c880d2b7b <_PyEval_EvalFrameDefault+13627>,
0x7f1c880d41b4 <_PyEval_EvalFrameDefault+19316>, 0x7f1c880d0ab7 <_PyEval_EvalFrameDefault+5239>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d0b6e <_PyEval_EvalFrameDefault+5422>,
0x7f1c880d2704 <_PyEval_EvalFrameDefault+12484>, 0x7f1c880d3c47 <_PyEval_EvalFrameDefault+17927>,
0x7f1c880d22f3 <_PyEval_EvalFrameDefault+11443>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>, 0x7f1c880d2377 <_PyEval_EvalFrameDefault+11575>,
0x7f1c880d2472 <_PyEval_EvalFrameDefault+11826>, 0x7f1c880d263a <_PyEval_EvalFrameDefault+12282>,
0x7f1c880d0e80 <_PyEval_EvalFrameDefault+6208>, 0x7f1c880d3ccb <_PyEval_EvalFrameDefault+18059>,
0x7f1c880d0ea1 <_PyEval_EvalFrameDefault+6241>, 0x7f1c880d0f36 <_PyEval_EvalFrameDefault+6390>,
0x7f1c880d36ff <_PyEval_EvalFrameDefault+16575>, 0x7f1c880d000c <_PyEval_EvalFrameDefault+2508>,
0x7f1c880d01f2 <_PyEval_EvalFrameDefault+2994>, 0x7f1c880d0d93 <_PyEval_EvalFrameDefault+5971>,
0x7f1c880d000c <_PyEval_EvalFrameDefault+2508>, 0x7f1c880d3766 <_PyEval_EvalFrameDefault+16678>,
0x7f1c880d37d0 <_PyEval_EvalFrameDefault+16784>, 0x7f1c880d3856 <_PyEval_EvalFrameDefault+16918>,
0x7f1c880d00c0 <_PyEval_EvalFrameDefault+2688>, 0x7f1c880d0180 <_PyEval_EvalFrameDefault+2880>,
0x7f1c880d683a <_PyEval_EvalFrameDefault+29178>, 0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337>,
0x7f1c880d29ac <_PyEval_EvalFrameDefault+13164>, 0x7f1c880d28c0 <_PyEval_EvalFrameDefault+12928>,
0x7f1c880d45b1 <_PyEval_EvalFrameDefault+20337> <repeats 94 times>}
#8 0x00007f1c881e95ec in _PyEval_EvalCodeWithName (_co=0x7f1c7beffd20, globals=<optimized out>,
locals=<optimized out>, args=args@entry=0x0, argcount=argcount@entry=0, kwnames=kwnames@entry=0x0, kwargs=0x0,
kwcount=0, kwstep=2, defs=0x0, defcount=0, kwdefs=0x0, closure=0x0, name=0x0, qualname=0x0)
at ../Python/ceval.c:3930
co = 0x7f1c7beffd20
f = 0x5623945bc020
retval = 0x0
fastlocals = 0x5623945bc188
freevars = 0x5623945bc188
x = <optimized out>
u = <optimized out>
total_args = <optimized out>
i = <optimized out>
n = 0
kwdict = 0x0
#9 0x00007f1c881e971e in PyEval_EvalCodeEx (_co=<optimized out>, globals=<optimized out>, locals=<optimized out>,
args=args@entry=0x0, argcount=argcount@entry=0, kws=kws@entry=0x0, kwcount=0, defs=0x0, defcount=0, kwdefs=0x0,
closure=0x0) at ../Python/ceval.c:3959
No locals.
#10 0x00007f1c881e974b in PyEval_EvalCode (co=<optimized out>, globals=<optimized out>, locals=<optimized out>)
at ../Python/ceval.c:524
No locals.
#11 0x00007f1c8b792a5d in Gui::InteractiveInterpreter::runCode (this=0x5623940cc410, code=0x7f1c7beffd20)
at /mnt/source/src/Gui/PythonConsole.cpp:327
lock = {gstate = PyGILState_LOCKED}
module = 0x7f1c8c886b30
dict = 0x7f1c8c894b40
presult = 0x7f1c7beffd20
#12 0x00007f1c8b7928de in Gui::InteractiveInterpreter::runSource (this=0x5623940cc410,
source=0x562395f45f88 "Import.open(u\"/mnt/files/Nova_C_Wall.stp\")") at /mnt/source/src/Gui/PythonConsole.cpp:305
code = 0x7f1c7beffd20
#13 0x00007f1c8b7930b1 in Gui::InteractiveInterpreter::push (this=0x5623940cc410,
line=0x56239407d0e8 "Import.open(u\"/mnt/files/Nova_C_Wall.stp\")") at /mnt/source/src/Gui/PythonConsole.cpp:387
more = false
source = {static null = {<No data fields>}, d = 0x562395204de0}
#14 0x00007f1c8b7951e6 in Gui::PythonConsole::runSource (this=0x5623940d6bd0, line=...)
at /mnt/source/src/Gui/PythonConsole.cpp:834
incomplete = false
lock = {gstate = PyGILState_UNLOCKED}
default_stdout = 0x562393d58a18
default_stderr = 0x562393d58a18
#15 0x00007f1c8b79479d in Gui::PythonConsole::keyPressEvent (this=0x5623940d6bd0, e=0x7ffc3ffc42f0)
at /mnt/source/src/Gui/PythonConsole.cpp:628
inputBlock = {p = 0x5623940eaad0, n = 8}
inputLine = {static null = {<No data fields>}, d = 0x56239509a480}
inputStrg = {static null = {<No data fields>}, d = 0x562394c326c0}
restartHistory = true
cursor = {d = {d = 0x56239509d9a0}}
inputLineBegin = {d = {d = 0x562395f47080}}
#16 0x00007f1c850174d7 in QWidget::event(QEvent*) () from /usr/local/Qt-5/lib/libQt5Widgets.so.5
#17 0x00007f1c850bd83e in QFrame::event(QEvent*) () from /usr/local/Qt-5/lib/libQt5Widgets.so.5
#18 0x00007f1c850c0523 in QAbstractScrollArea::event(QEvent*) () from /usr/local/Qt-5/lib/libQt5Widgets.so.5
#19 0x00007f1c85185035 in QPlainTextEdit::event(QEvent*) () from /usr/local/Qt-5/lib/libQt5Widgets.so.5
#20 0x00007f1c84fd7f1c in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
<!------ SNIPPED ------->
#40 0x0000562392b83bd0 in main (argc=2, argv=0x7ffc3ffc5dd8) at /mnt/source/src/Main/MainGui.cpp:301
stdcout = {<std::basic_streambuf<char, std::char_traits<char> >> = {<No data fields>}, buffer = ""}
stdclog = {<std::basic_streambuf<char, std::char_traits<char> >> = {<No data fields>}, buffer = ""}
stdcerr = {<std::basic_streambuf<char, std::char_traits<char> >> = {<No data fields>}, buffer = ""}
oldcout = 0x7f1c837c86e0
oldclog = 0x7f1c837c8620
oldcerr = 0x7f1c837c8620
