[BUG] Line.intersect / intersectCC between colinear line -> Segmentation fault
Cyril
Post by Cyril »
I found an issue using Line.intersect / intersectCC. Same for LineSegment.
  • Steps to reproduce :
    1. Open FreeCAD
    2. Run following code in python console :
    import Part
    doc = FreeCAD.newDocument()
    v = FreeCAD.Vector
    w1 = Part.makePolygon([v(0,0,0), v(0,10,0), v(-5, 5, 0), v(0,0,0)])
    w2 = Part.makePolygon([v(0,2,0), v(0,8,0), v(5, 5, 0), v(0,2,0)])
    Part.show(w1)
    Part.show(w2)
    e1 = w1.Edges[0]
    e2 = w2.Edges[0]
    e1.Curve.intersectCC(e2.Curve)
  • Log : see attachment
  • Error message :
    #0  /usr/lib/libc.so.6(+0x3bfb0) [0x7f1718865fb0]
    #1  0x7f168e3003a4 in Extrema_ExtCC::Points(int, Extrema_POnCurv&, Extrema_POnCurv&) const from /usr/lib/libTKGeomBase.so.7+0x54
    #2  0x7f168eae20d7 in GeomAPI_ExtremaCurveCurve::Points(int, gp_Pnt&, gp_Pnt&) const from /usr/lib/libTKGeomAlgo.so.7+0x57
    #3  0x7f1690dbe550 in Part::GeomCurve::intersect(opencascade::handle<Geom_Curve>, opencascade::handle<Geom_Curve>, std::vector<std::pair<Base::Vector3<double>, Base::Vector3<double> >, std::allocator<std::pair<Base::Vector3<double>, Base::Vector3<double> > > >&, double) from /usr/lib/freecad/lib/Part.so+0x3e0
    #4  0x7f1690dbeb2e in Part::GeomCurve::intersect(Part::GeomCurve*, std::vector<std::pair<Base::Vector3<double>, Base::Vector3<double> >, std::allocator<std::pair<Base::Vector3<double>, Base::Vector3<double> > > >&, double) const from /usr/lib/freecad/lib/Part.so+0xfe
    #5  0x7f1690cacfbe in Part::GeometryCurvePy::intersectCC(_object*) from /usr/lib/freecad/lib/Part.so+0x9e
    #6  0x7f1690cad1af in Part::GeometryCurvePy::staticCallback_intersectCC(_object*, _object*) from /usr/lib/freecad/lib/Part.so+0x1f
    #7  /usr/lib/libpython3.8.so.1.0(PyCFunction_Call+0xf3) [0x7f1719ffa5d3]
    #8  /usr/lib/libpython3.8.so.1.0(_PyObject_MakeTpCall+0x230) [0x7f1719fa3220]
    #9  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4c9a) [0x7f171a00c97a]
    #10  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x2fa) [0x7f1719fd809a]
    #11  /usr/lib/libpython3.8.so.1.0(PyEval_EvalCodeEx+0x3a) [0x7f1719fd8cca]
    #12  /usr/lib/libpython3.8.so.1.0(PyEval_EvalCode+0x1c) [0x7f171a06473c]
    #13  0x7f171affbce6 in Gui::InteractiveInterpreter::runCode(PyCodeObject*) const from /usr/lib/freecad/lib/libFreeCADGui.so+0x66
    #14  0x7f171affc54c in Gui::InteractiveInterpreter::runSource(char const*) const from /usr/lib/freecad/lib/libFreeCADGui.so+0xac
    #15  0x7f171affc62d in Gui::InteractiveInterpreter::push(char const*) from /usr/lib/freecad/lib/libFreeCADGui.so+0xbd
    #16  0x7f171affc834 in Gui::PythonConsole::runSource(QString const&) from /usr/lib/freecad/lib/libFreeCADGui.so+0xf4
    #17  0x7f171affd107 in Gui::PythonConsole::runSourceFromMimeData(QString const&) from /usr/lib/freecad/lib/libFreeCADGui.so+0x737
    #18  0x7f171affeeac in Gui::PythonConsole::insertFromMimeData(QMimeData const*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x1cc
    #19  /usr/lib/libQt5Widgets.so.5(+0x356664) [0x7f1719b2d664]
    #20  0x7f1719b32a13 in QWidgetTextControl::processEvent(QEvent*, QMatrix const&, QWidget*) from /usr/lib/libQt5Widgets.so.5+0x193
    #21  0x7f1719b28b1c in QWidgetTextControl::processEvent(QEvent*, QPointF const&, QWidget*) from /usr/lib/libQt5Widgets.so.5+0x5c
    #22  0x7f1719b03aa4 in QPlainTextEdit::keyPressEvent(QKeyEvent*) from /usr/lib/libQt5Widgets.so.5+0x254
    #23  0x7f171b029653 in Gui::TextEdit::keyPressEvent(QKeyEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x23
    #24  0x7f171affe097 in Gui::PythonConsole::keyPressEvent(QKeyEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x277
    #25  0x7f1719976e1b in QWidget::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x88b
    #26  0x7f1719a2822f in QFrame::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x1f
    #27  0x7f1719a2af7a in QAbstractScrollArea::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x26a
    #28  0x7f1719b032b9 in QPlainTextEdit::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0xc9
    #29  0x7f1719932472 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x82
    #30  0x7f171993c3c4 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0xa74
    #31  0x7f171ae1f069 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
    #32  0x7f1718e99832 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x182
    #33  /usr/lib/libQt5Widgets.so.5(+0x1bdf3e) [0x7f1719994f3e]
    #34  0x7f1719932472 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x82
    #35  0x7f171993bc89 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x339
    #36  0x7f171ae1f069 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
    #37  0x7f1718e99832 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x182
    #38  0x7f171925e66d in QGuiApplicationPrivate::processKeyEvent(QWindowSystemInterfacePrivate::KeyEvent*) from /usr/lib/libQt5Gui.so.5+0x16d
    #39  0x7f17192639ba in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /usr/lib/libQt5Gui.so.5+0x26a
    #40  0x7f171923cc2c in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Gui.so.5+0xbc
    #41  /usr/lib/libQt5XcbQpa.so.5(+0x66a2c) [0x7f17133aba2c]
    #42  /usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x27e) [0x7f17169d239e]
    #43  /usr/lib/libglib-2.0.so.0(+0x6c1b1) [0x7f17169d41b1]
    #44  /usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x31) [0x7f17169d41f1]
    #45  0x7f1718ef1cc0 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x60
    #46  0x7f1718e9839c in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x12c
    #47  0x7f1718ea03a6 in QCoreApplication::exec() from /usr/lib/libQt5Core.so.5+0x96
    #48  0x7f171ad93222 in Gui::Application::runApplication() from /usr/lib/freecad/lib/libFreeCADGui.so+0x15e2
    #49  freecad(main+0x759) [0x5562249605d9]
    #50  /usr/lib/libc.so.6(__libc_start_main+0xf3) [0x7f1718851153]
    #51  freecad(_start+0x2e) [0x5562249608fe]
  • FreeCAD infos :
    OS: Manjaro Linux (GNOME/gnome)
    Version: 0.19 (Git)
    Hash: 49e4e45ff38b0459f0f9a76df634f6da4995b731
    Python version: 3.8.1
    Qt version: 5.14.0
    Locale: French/Switzerland (fr_CH)
FreeCAD.log
(17.85 KiB) Downloaded 64 times
I blog about HVAC / BIM / Energy : pythoncvc.net. If you like you can follow the RSS feed.
vocx
Re: [BUG] Line.intersect / intersectCC between colinear line -> Segmentation fault
Post by vocx »
Cyril wrote: Sat Jan 11, 2020 5:24 pm Hi,
This code does not produce a crash in my system.
>>> import Part
>>> # App.setActiveDocument("Unnamed")
>>> # App.ActiveDocument=App.getDocument("Unnamed")
>>> # Gui.ActiveDocument=Gui.getDocument("Unnamed")
>>> v = FreeCAD.Vector
>>> Part.show(w1)
>>> Part.show(w2)
>>> e1 = w1.Edges[0]
>>> e2 = w2.Edges[0]
[<Point (0,0,0) >]
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.19240 (Git)
Build type: Unknown
Hash: f97eb7026dfd59745829d4d8fb4831aa6354c099
Python version: 3.6.9
Qt version: 5.9.5
Your version is one commit older than my version.
You are trying to find the intersection of two co-linear edges (in the picture, it's where the two triangles meet). This would result in an infinite number of points; in my system it just returns the origin.
Cyril
Post by Cyril »
vocx wrote: Sat Jan 11, 2020 10:14 pmYour version is one commit older than my version.
Thanks for testing. Yes, wmayer did commit while I was writing my bug report ^^ but Iooked at the last commit content and I am almost 100% sure that it is absolutely not related.
vocx wrote: Sat Jan 11, 2020 10:14 pmYou are trying to find the intersection of two co-linear edges (in the picture, it's where the two triangles meet). This would result in an infinite number of points; in my system it just returns the origin.
Yes I know. I was considering to use it in a loop handling the 3 cases. 1. I get an intersection. 2. I get no intersection. 3. I get (None or something like this) -> parallel or collinear. I am surprised that it returns Point(0,0,0) it might be confused with a real intersection at the origin. No ?
vocx wrote: Sat Jan 11, 2020 10:14 pm OCC version: 7.3.0
Maybe related to OCC 7.4 then ?
looo
Post by looo »
crashes with:
Version: 0.19.19242 (Git)
Hash: 2d752745c298108a1d7ec756bd0ca57818c7a174
Python version: 3.7.6
works with:
Version: 0.19.19066 (Git)
Hash: c766d757912ded11d41bc825f82c47a8428396ad
Seems like occt7.4 introduced a new bug. :evil:
Cyril
Post by Cyril »
looo wrote: Sun Jan 12, 2020 6:49 pm Seems like occt7.4 introduced a new bug. :evil:
Thanks for testing.
I opened an issue on bug tracker : https://www.freecadweb.org/tracker/view.php?id=4247
looo
Post by looo »
It would be interesting to see what the diff between occt7.4 and occt7.3 for the function: GeomAPI_ExtremaCurveCurve::Points(int, gp_Pnt&, gp_Pnt&) looks like. There are several regression commits for occt but I didn't see one which is related to the problem reported here.
looo wrote: Mon Jan 13, 2020 2:46 pm It would be interesting to see what the diff between occt7.4 and occt7.3 for the function: GeomAPI_ExtremaCurveCurve::Points(int, gp_Pnt&, gp_Pnt&) looks like. There are several regression commits for occt but I didn't see one which is related to the problem reported here.
Shouldn't this be possible using git blame ?
looo
Post by looo »
Kunda1 wrote: Mon Jan 13, 2020 3:01 pm Shouldn't this be possible using git blame ?
My problem is that I have no accesss to the git repo of opencascade.
ickby
Post by ickby »
As it is a regression one could also report it on the occ bug tracker, usually those regressions are fixed by them.
ickby wrote: As it is a regression one could also report it on the occ bug tracker, usually those regressions are fixed by them.
gAdlike wrote: pinged by pinger macro
kkremitzki wrote: pinged by pinger macro
Quaoar wrote: pinged by pinger macro
Hi, is one of you available to make an upstream ticket ?
