Is this a bug with tangency?
sliptonic
Post by sliptonic »
If I create two unconnected segments both with a horizontal constraint on them, select them, and apply a tangent (co-linear) constraint, the constraint seems to be applied but not solved. No error either.
However, If the segments don't have the horizontal contraints applied, it works as expected. Applying the horizontal constraint after continues to work.
If the segments both have the horiz constraint and I select one segment and a vertex from the other, the constraint is applied and solved as expected.
Bottom line, one way or the other, I can get two segments to be co-linear, but the behavior isn't consistent. I'm wondering if this is intended behavior or a bug. If the latter, I'll add a report on mantis.
Re: Is this a bug with tangency?
OK, I can confirm what you observed. The important point is that you select the lines and apply the tangency. If you select the end points instead then the tangency always works independent of the horizontal constraint set or not.
abdullah
Post by abdullah »
Feel free to create a mantis ticket and assign it to me. I will come back to it when I have some coding time available.
triplus
Post by triplus »
sliptonic wrote:If I create two unconnected segments both with a horizontal constraint on them, select them, and apply a tangent (co-linear) constraint, the constraint seems to be applied but not solved. No error either.
This sound similar to what was discussed here:
viewtopic.php?f=10&t=12599#p101204
sliptonic
Post by sliptonic »
issue #0002284 created. Either I don't have permission to assign or I don't have a clue how to do that :oops: Thanks abdullah.
jmaustpc
Post by jmaustpc »
sliptonic wrote:bug 0002284 created. Either I don't have permission to assign or I don't have a clue how to do that :oops: Thanks abdullah.
Assigned to Abduallah...
thanks for writing up the ticket...
Jim
abdullah
Post by abdullah »
I am with this now. There are several issues:
1. No error is shown when there is obviously an issue
2. There is a problem with the solver. As DeepSOIC says this introduces a redundancy in the linear system. We are aware that these cases exist and are not easy to fix. However, having a collection of sketches that make the solver misbehave is the only way of actually eventually solving them... Thanks for reporting this.
NOTE to Mantis adms: Is there a way of creating a tag "solver issues" or similar, so that we can actually tag mantis tickets and retrieve them easily?
I will debug 1 now.
Unrelated to the bug itself, if I want co-linearity between horizontal lines, I normally use point on object (one end of one line, on the other line). I try to minimize the usage of tangency except when absolutely necessary. No reason, however why it should not work.
abdullah
Post by abdullah »
About 1)
Branch contains a fix:
https://github.com/abdullahtahiriyo/Fre ... ue_0002284
so that it is shown like this:
I have changed the text colour for solved and unsolved so that it can be seen more clearly :).
Please check if this behaviour is acceptable, so that I do a pull request.
About 2)
Definitely the solvers have a problem with that definition of tangency. As all solvers have it, maybe the definition of the constraint (error/gradient) does not work great in that specific situation. The fact that selecting the points tangency, which is implemented using DeepSOIC's AngleViaPoint also seems to point in that direction. This issue remains for further investigation, when we revisit the solvers.
