Post Pipeline display scale
Moderator: bernd
Hi, I am running a FEM on a optical mirror for self deflection. The FEM results are fine surface deformation in the nm range (+68nm and -53nm) typical. I need to display the deformation image in a gray scale as per the Post Pipeline option, but it only goes to 6 decimals. As a result it does not display the surface correctly. Is there a way to set the limits smaller? I am not confident scaling everything up will provide the correct results
Re: Post Pipeline display scale
The easiest way might be to export the results to vtk file and postprocess them using ParaView.
