pipeline blow up ==> starter kit
Moderator: bernd
thschrader
Post by thschrader »
If you like to carry out actions that are in the public spotlight, scaring people,
but like to stay in the background, this is the right stuff for you.
What do you need:
A metal corrosive liquid (the red cylinder).
A timing device.
A way to attach both to the inspection-robot, who runs through the pipeline.
This is the hardest part, if you are not the owner. But not impossible.
Estimate the run-time of the robot until it reaches your zone of interest.
After dropping the liquid, the corrosion-process starts. When the corrosion is deep
enough, the pipe suddenly breaks. Which sounds like an explosion,
a nice side effect. You can see the basic result at the pictures below.
Bonus points of this operation:
No explosives needed. After all, you are not a criminal. Or is it?
No sophisticated mil-ops necessary, this is a one-man-show, my friend.
Easy to build, you can buy all parts in your local DIY-shop.
Backdraw:
Keep in mind, that most normal people hate it, when you blow up stuff which
needs years to build. Now you are on the top 10 list of wanted people.
Maybe thats the reason, why you cant sleep at night...
pipeblow_starterkit.FCStd
(15.82 KiB) Downloaded 21 times
