FEM Result Export to File
Moderator: bernd
I would like to export my FEM results as a usable model. I can replicate similar requests I found while searching (https://forum.freecadweb.org/viewtopic.php?t=68433 and https://forum.freecadweb.org/viewtopic.php?f=18&t=48882) to create an array of Vector objects. How do I put this in a form which I can export as a mesh or solid? As an alternative, when I try to do something dead-simple like File>Export...>obj to take a copy of the result mesh, I return a mostly empty file. It feels like I am missing something obvious. Is there some way to pipe the Vector array into a mesh file which I can save?
OS: Ubuntu 20.04.5 LTS (KDE/plasma)
Version: 0.19.
Branch: unknown
Hash: 0d9536ed3e8c7f40197b5606e1b7873625e1d6fe
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
Example file seems unnecessary for this question, but I can provide a cube on request.
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
OCC version: 7.5.2
Re: FEM Result Export to File
This tool may help you: FEM FemMesh2Mesh
Thanks.
I used the script to generate the obj-mesh from FEM-result.
How can I get the deformed mesh? As a start to run FEM
with shell imperfections.
That tool seemed promising, but it seems it only outputs the starting mesh not the displacement mesh. It looks like thschrader is asking the same thing.
@thschrader @whoneyc According to the description on the wiki, this tool can export the deformed mesh but only for solid elements. For shell elements, undeformed mesh is exported. But maybe it wouldn’t be very difficult to add a code that could handle this.
I agree, but this is my first time looking at FreeCAD scripting. Please bear with my newb problems here.
I have two methods to generate similar outputs. The first is to look at the FemMesh2Mesh output which follows the format:
out_mesh = femmesh.femmesh2mesh.femmesh_2_mesh(FreeCAD.ActiveDocument.ResultMesh.FemMesh)
Mesh.show(Mesh.Mesh(out_mesh))
FreeCAD.ActiveDocument.ResultMesh.ViewObject.hide()
doc = App.ActiveDocument
resnodes_notdeformed = list(doc.ResultMesh.FemMesh.Nodes.values())
displacements = doc.CCX_Results.DisplacementVectors
sum = [a + b for a, b in zip(resnodes_notdeformed, displacements)]
When I attempt to run
Mesh.show(Mesh.Mesh(sum))
OK. But what must I do? Workflow?
Thanks, Thomas
Select the mesh object and the result file “CCX_Results”. Click FEM mesh to mesh. The new mesh object should appear (corresponding to deformation scale = 1).
For me it works for 3D as well as 2D mesh. Wiki seems to be outdated.
Note that for buckling and frequency analysis, deformation is normalized. CalculiX finds only the shape, not the scale. So the scale is real only for static (or thermomechanical) analysis.
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.20.1.29177 +233 (Git) Snap 245
Branch: tag: 0.20.1
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
OK. I think it would be nice to add a scale as a parameter, but for now, you can do it manually:
1) Copy the source code to the FreeCAD python console
https://github.com/FreeCAD/FreeCAD/blob ... #L171-L180
where the highlighted block is changed to
triangle = [myFemMesh.getNodeById(face_nodes[0]) + dispVec0 * 100,
myFemMesh.getNodeById(face_nodes[1]) + dispVec1 * 100,
myFemMesh.getNodeById(face_nodes[2]) + dispVec2 * 100]
output_mesh.extend(triangle)
# print("my triangle: ", triangle)
if len(face_nodes) == 4:
dispVec3 = myResults.DisplacementVectors[myResults.NodeNumbers.index(face_nodes[3])]
triangle = [myFemMesh.getNodeById(face_nodes[2]) + dispVec2 * 100,
myFemMesh.getNodeById(face_nodes[3]) + dispVec3 * 100,
myFemMesh.getNodeById(face_nodes[0]) + dispVec0 * 100]
2) select CCX_Results object and mesh object
3) run the modified function by
import Mesh
out_mesh = femmesh_2_mesh(FreeCAD.ActiveDocument.ResultMesh.FemMesh, FreeCAD.ActiveDocument.CCX_Results)
