[SOLVED] GMSH error
Moderator: bernd
HarryvL
[SOLVED] GMSH error
Post by HarryvL »
I am getting the following error with GMSH, resulting in no mesh:
10:52:24  Active analysis found: Analysis
10:52:24    ElementDimension: 3
10:52:24    No Group meshing for analysis.
10:52:24    /tmp/fcfem_570b24oo/Box_Geometry.brep
10:52:24    /tmp/fcfem_570b24oo/Box_Mesh.unv
10:52:24    /tmp/fcfem_570b24oo/shape2mesh.geo
10:52:24    gmsh
10:52:24  Unexpected error when creating mesh: File to load not existing or not readable: /tmp/fcfem_570b24oo/Box_Mesh.unv
10:52:24  Gmsh had warnings ...
10:52:24  File to load not existing or not readable: /tmp/fcfem_570b24oo/Box_Mesh.unv
OS: Ubuntu 20.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.30342 (Git)
Build type: Unknown
Hash: f28000c77a8526ba2260f947075e81399e26d46a
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
  * main.py
user1234
Re: GMSH error
Post by user1234 »
HarryvL wrote: Sat Sep 10, 2022 9:04 am resulting in no mesh
No mesh or a invalid cluttered mesh?
There were issues with VTK9.x and the mesh import of gmsh. There are solved, but maybe now it does not work with VTK7.x anymore. But your error message looks different.
What gmsh version are you using? Are you using the from the repository or the precompiled bin of the gmsh for linux https://gmsh.info/bin/ (works for me great). Generally i would update to VTK9.x. I did not check that, but it should be in the repository (on Debian 11 it is in the repository).
Greetings
user1234
HarryvL
Re: GMSH error
Post by HarryvL »
No mesh at all. I have version 4.4.1 installed via synaptic package manager. This never gave any problems and still works with older FC versions. However, not anymore for me with the latest development branch.
HarryvL
Re: GMSH error
Post by HarryvL »
I upgraded to the latest stable version just now (4.10.5) and my problem disappeared :)
