Altair has opensourced Radioss into OpenRadioss (Maybe we can add it as a FEM solver?)
Moderator: bernd
NewJoker
Post by NewJoker »
Just to let you know, today Altair turned their advanced dynamic FEA code Radioss into open-source solution: https://www.openradioss.org/
That’s a potential revolution in open-source FEA software. Maybe this solver could be included in the FreeCAD FEM module in the future…
Reason: Updated thread title to be less generic
Re: Altair has opensourced Radioss into OpenRadioss (Maybe we can add it as a FEM solver?)
Thanks for the heads up.
Here's the announcement: https://openradioss.atlassian.net/wiki/ ... +Community
Here's the repository: https://github.com/OpenRadioss/OpenRadioss
NewJoker
Post by NewJoker »
The only problem is that this code seems to be meant for Linux only but maybe it could be adapted for Windows as well.
Sam_CAD
Post by Sam_CAD »
Thanks for this information. :)
I don't have much experience in Freecad but we need to have shell mesh if we want to run some crash analysis with Radioss.
Is it possible with Freecad to generate shell mesh ?
NewJoker
Post by NewJoker »
Sam_CAD wrote: Sat Sep 10, 2022 5:47 pm Is it possible with Freecad to generate shell mesh ?
Yes, both meshers used by FreeCAD (Netgen and Gmsh) can generate shell meshes.
Sam_CAD
Post by Sam_CAD »
Thanks for your reply
johnwang
Post by johnwang »
NewJoker wrote: Sat Sep 10, 2022 7:43 am The only problem is that this code seems to be meant for Linux only but maybe it could be adapted for Windows as well.
Anyone know how to do 'sh' under Windows?
2>'sh' is not recognized as an internal or external command,
In its CMakeLists.txt,
'sh' is needed here:
#include always rebuild
add_custom_command(
         OUTPUT
            ${Build_includes_directory}/__foo.inc
            ${Build_includes_directory}/build_info.inc
         COMMAND
            sh ../../Compiling_tools/script/or_compile_info_cm.sh linux64 0 e 0 linux64  > ${Build_includes_directory}/build_info.inc
What this 'sh' does? How I simulate it under Windows? Thanks.
johnwang
Post by johnwang »
Kunda1 wrote: Sun Sep 11, 2022 4:45 am 'sh' spawns a shell. See https://www.baeldung.com/linux/sh-vs-bash
I guess it run this 'or_compile_info_cm.sh' script to create a file named build_info.inc?
Asked here: https://github.com/OpenRadioss/OpenRadi ... ssions/426
