[solved] Constraint direction coul not be reversed
Moderator: bernd
mwlandolsi
Post by mwlandolsi »
Hello
Open new file then Part WB
insert a cube and set length, for example 100 mm.
apply constraint on edge (see image) and then check "Reverse direction" the direction could not be reversed.
Screenshot from 2022-08-07 10-18-18.png (40.67 KiB) Viewed 851 times
Screenshot from 2022-08-07 10-18-09.png (32.75 KiB) Viewed 851 times
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 0.20.29177 (Git) AppImage
  * sheetmetal 0.2.55
  * fcgear 1.0.0
  * frame 0.5.3
  * dodo
  * Assembly3 0.11.3
  * Curves 0.5.3
  * freecad_frame 0.1.0
  * 3DfindIT 1.2.0
  * lattice2 1.0.0
  * fasteners 0.3.50
NewJoker
Re: Constraint direction coul not be reversed
Post by NewJoker »
You can select one of the vertical edges for Direction. Then it should be possible to reverse the load.
mwlandolsi
Is it mandatory to select the edge of direction ? Is there a default orientation or adding direction by vector orientation ?
Yes, I Know, but when you deselect a vertical edge, the direction could also be inverted. But suppose that you do not have a vertical edge, the case of cylindrical beam. What should I do ?
NewJoker
Post by NewJoker »
When the Direction field is empty, the force acts in the normal direction. It should be possible to reverse it.
When there are no straight edges/faces to pick, you can create a datum or Draft geometry and use it for direction specification.
Jee-Bee
Post by Jee-Bee »
On surfaces is what you said kind of expected... But on edges it is kind of weird since it choose a direction but based on what... since the force can act in 360 degrees.
mwlandolsi
Thank you all for your replay.
