I am still convinced that the issue is with the test and not the updated code. The test should call the "calculate_principal_stress" function and not the "calculate_principal_stress_reinforced" function, which is no longer used in the updated code.HarryvL wrote: ↑Mon Jun 13, 2022 6:56 pm I can't build - have an issue with shiboken2 library.
I think the error is easy to fix by renaming method "calculate_principal_stress" to "calculate_principal_stress_reinforced" everywhere (3 locations) in resulttools.py. That or change the test to call calculate_principal_stress instead. Not elegant, but it should work. See attached:
resulttools.py
Please note: the treatment of principal stress vectors should not depend on the material used. They are the same for all materials
@bernd can you please help out?
