[bug 6973] adding a pipeline filter changes transparency
Moderator: bernd
I noticed a bug when adding a pipeline filter:
- set the transparency of a pipeline object to e.g. 75
- select this pipeline and add a filter of your choice
result: the transparency of the pipeline is lost
This bug only occurs if the pipeline shows no field yet (Field is "None").
This is a bit annoying because the transparency was set that one can see the new filter result immediately.
Re: [bug 6973] adding a pipeline filter changes transparency
For me, it is even worse. When i only add a little bit ( > 0 ) of transparency, the colorbar is invalid. When i reset it to 0, then it works again.
But when i add a transparency and add a filter on it, then i have to delete the filter and edit the pipeline and change the field or the mode, to get it work again.
Generally no (pipeline) transparency, even on filters, does work for me.
Greetings
user1234
Greetings
user1234
It is repeatable on the file on this post, https://forum.freecadweb.org/viewtopic. ... 7&#p600402.
vtk9.0.1, but can be also graphic card/driver related.
Greetings
user1234
I cannot reproduce. I don't see there the points as ion your screenshots. So what do i have to do (step by step?)user1234 wrote: ↑Mon Jun 06, 2022 10:40 pm It is repeatable on the file on this post, https://forum.freecadweb.org/viewtopic. ... 7&#p600402.
VTK 9.0.x is known to make problems, therefore we kept VTK 8.2 for the Windows LibPack. Bug VTK 9.1 is available since a while and you should upgrade to this.
OK, i have expressed it very extremly inconsequent (colorbar --> color of the bar (beam)). I mean, that the color of the points gets incorrect.
- open the file
- go the FEM wb
- either
- double click on (open) the ResultPipeline
- change the transparency > 0
- the result is that the color of the wireframe is incorrect
- click OK
- or
- click on the ResultPipeline
- go to the property view
- go on the tab view
- then
- change the transparency to 0
- the result is that the color of the wireframe is correct
- then
- the result is that the color of the wireframe is again incorrect
- then
- add any filter, here for example Region clip filter on the pipeline
- click in the task view of the filter on Create --> Plane (result does not matter)
- click OK
- hide the filter and planes (all under the ResultPipeline) for better overview
- the result is that the color of the wireframe is still incorrect, what is unexpected, because before correcting it to 0 solved the visual error
- to solve it
- easiest way is to set the transparency to 0 and then change the field (for example from Displacement to van Mises Stress), the order is not important, but both must be changed, even when the transparency was 0 before.
here a screencast:
version:
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.29055 (Git)
Hash: b9b21ddac562f03cef162bb1f7feb4eea3de8b1e
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, OCC 7.6.2
The problem in that case is, that on Debian there is no vtk8, only a vtk7.1.1 and vtk9.01 is still the newest one. And this can often take ages, till they update. Also afaik, there is a paraview vtk dependeny issue atm (not for me since i do not use paraview). Also on other system the updates can take longer.
And also FreeCAD works with vtk9 since a very short time ago, see https://forum.freecadweb.org/viewtopic. ... 28#p583828.
Greetings
user1234
Confirmed (VTK 8.2). Maybe @wmayer knows why since he recently fixed the transparency.
To reproduce the issue, one can just
- select any result pipeline
- change its transparency to e.g. "4"
- IMPORTANT: the Display Mode must be set to "nodes" or "wireframe". With the "Surface" display mode, the bug does not occur.
Yes, this works. Sorry for not testing it, but i never use surface mode, since it is a little bit unpractical (for me, not in general).
Greetings
user1234
Confirmed if Display Modes is set to Nodes. For Surface it works fine.
However, I don't think it's a FreeCAD but either a graphic driver issue or a limitation of Coin3D. For those who are interested in debugging the problem: Transparency is handled (or not ) inside SoShape::shouldGLRender.
We don't use vtk for rendering but only its algorithms. Because it's a pure rendering problem it's unlikely that it's related to the used vtk version.VTK 9.0.x is known to make problems, therefore we kept VTK 8.2 for the Windows LibPack. Bug VTK 9.1 is available since a while and you should upgrade to this.
Thanks for having a look!
I learned recently that the mode or representation is preferred for professional inspections of results. Therefore not providing transparencies in the nodes representation is a an issue.
However, the bug is also in FC 0.19.
I will report it later as issue that this is not forgotten.
