[fixed] ResultShow dialog: translating "Peeq"
Moderator: bernd
Right now the "ResultShow.ui" dialog has a string in it labelled "Peeq" (e.g. the equivalent plastic strain). That string is currently marked for translation -- is that correct? If so, are translators expected to also yield a short acronym, or can they spell out the term?
Re: ResultShow dialog: translating "Peeq"
@NewJoker any idea?
But peeq is also output version for the *EL File.
So we should be carefull that the reference to the functions are not translated...
https://www.feacluster.com/CalculiX/ccx ... mentoutput
https://www.feacluster.com/CalculiX/ccx ... tml#elfile
We don’t translate it in practice and just talk about PEEQ. Only in some research papers we translate it but then the full name must be used (equivalent plastic strain is directly translated) because abbreviating it in Polish doesn’t make sense. So I would leave it as PEEQ (upper case recommended) since full name is too long to be used in FreeCAD.
Perfect, thanks -- I'll make that adjustment.
after scratching my head and spent time on the net (it's not my field), in French, they also use that. I guess Chennes you are dealing with Crowdin. thank you.
