Elmer Solver - Constraint flow volocity
Moderator: bernd
ziz
Post by ziz »
I'm trying to simulate an airfoil subjected to a parabolic inflow.
Is there a way to define an equation for the flow velocity constraint in Elmer Solver?
In the Freecad interface, anything other than a number is apparently not allowed
NewJoker
Re: Elmer Solver - Constraint flow volocity
Post by NewJoker »
If you want to simulate the flow of air around an airfoil, try the CfdOF addon workbench. It's really powerful and well implemented.
thschrader
Post by thschrader »
ziz wrote: Mon May 16, 2022 2:17 pm I'm trying to simulate an airfoil subjected to a parabolic inflow.
You must edit the sif-file after case writing.
See Elmer Tutorial Nr. 19:
http://www.nic.funet.fi/index/elmer/doc ... orials.pdf
ziz
Post by ziz »
thschrader wrote: Tue May 17, 2022 7:16 am
This is precisely what I needed. Thank you!
uwestoehr
Post by uwestoehr »
Hello @ziz , I just implemented direct support to enter equations to the velocity constraint dialog: https://wiki.freecad.org/FEM_Constraint ... y#Formulas
This feature will be available for the next major FreeCAD release but you can try it out right now if you are on Windows by using this installer:
https://github.com/FreeCAD/FreeCAD-Bund ... taller.exe
or next week with the next weekly builds for Linux and MacOS: https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
Note: when you use a weekly build you must recreate existing flow velocity constraints.
In the https://wiki.freecad.org/FEM_Examples check the flow examples as they use this functionality.
