FEM Pipeline units on last dev versions
Moderator: bernd
uwestoehr
Re: FEM Pipeline units on last dev versions
Post by uwestoehr »
wmayer wrote: Mon May 30, 2022 12:11 pm Fixed with git commit c5296fbb925
many thanks!
Intermediate feedback: I tested the state from this morning 6AM on 3 more PCs and it works well.
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Mon May 30, 2022 2:01 pm Final feedback: I tested the state from this morning 6AM on 3 more PCs and it works well.
Tested now on 7 PCs and it works well.
user1234
Post by user1234 »
uwestoehr wrote: Mon May 30, 2022 12:59 am
uwestoehr wrote: Mon May 30, 2022 12:14 am However, there is a bug that the decimal settings is not taken into account: When max - min < 1/decimals, we must use scientific notation I will have a look.
Fixed: https://github.com/FreeCAD/FreeCAD/commit/79c218ad9
Yes, it works now, thanks!
Adjusting the screen also works now fluent.
I know, i am a nickpicker, but maybe one suggestion. When i change the decimals, it works. But when i change the type of the result, while the task is still open, it changes the decimals automatic. When i open the bar settings and click OK, it does not change anything, even when the dialog says, that the decimals have an other value. So you have to force to change it, that it works really correct. Can we change it, that the settings stays as the are, as long the task is not closed?
I hope, you understand what i mean, see:
1.webm
(400.5 KiB) Downloaded 27 times
Greetings
user1234
uwestoehr
Post by uwestoehr »
user1234 wrote: Tue May 31, 2022 1:19 pm I know, i am a nickpicker,
This is not nitpicking, this is a real bug - when changing the result vector field, the set number of decimals is ignored.
This should be fixed.
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Tue May 31, 2022 3:05 pm This is not nitpicking, this is a real bug - when changing the result vector field, the set number of decimals is ignored.
I reported this now as bug:
https://github.com/FreeCAD/FreeCAD/issues/6950
I assume the fix should not be tricky, however, I cannot have a look right now.
uwestoehr
Post by uwestoehr »
@wmayer , there is still a bug:
- assure that a panel is open (e.g. report view or Python)
- view a pipeline of your choice
- now close the panel
result: the color bar moves to the right window border and the labels are not visible at all:
Can you reproduce this?
uwestoehr wrote: Sun Jun 05, 2022 3:09 pm Can you reproduce this?
No, it works fine for me. What happens if you resize the window after hiding the Python console?
uwestoehr
Post by uwestoehr »
wmayer wrote: Sun Jun 05, 2022 6:02 pm No, it works fine for me. What happens if you resize the window after hiding the Python console?
If I make the window smaller, nothing:
Only when I make the window larger, the labels become visible again.
I already looked in the code bug don't see why this happens.
By the way, the issue does not occur on showing a panel when there was none shown before.
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Sun Jun 05, 2022 8:18 pm Only when I make the window larger, the labels become visible again.
No. It is even weirder:
- increasing the window slightly does not fix the issue
- only increasing it fast does
- however decreasing is fast does not fix it
I am baffled.
To test if the passed size and computed width is correct add the print statement to the function SoFCColorBarBase::getBounds:
Base::Console().Message("Size: (%d, %d), Width: %f\n", size[0], size[1], boxWidth);
Look the values plausible? The values for boxWidth may vary by ~ +/- 0.3. (In my test they were between [1.8, 2.1] where most values were 1.84). What does happen to boxWidth after hiding the Python console?
