Hello, just a general question;
do we have somewhere a timeplan of the coming improvements to FEM module?
If I am not wrong, at now two parts with contact cannot be simulated ( as two parts with 2 different materials, as example).
Thanks for help
Francesco
Question: FEM Roadmap?
Moderator: bernd
Reason: Updated thread title to be less generic
Re: FEM improvement
There's no such plan. Currently, we lack devs for this module and any help with coding is appreciated. There are a few features that would significantly improve the FEM workbench. In my opinion, those are (starting from the most crucial one):
1. Rigid body constraint
2. Support for multiple meshes and thus possibility to define contact between touching (not separated) faces - that's likely what you meant
3. Beams with arbitrary cross-section
4. Keyword editor
5. Simple creation of node and element sets
4. Keyword editor
Re: FEM improvement
I have a few times thought about implementing this feature. But my main problem is that i have only one time and to many thinks i want to do. I think(i'm not sure) that if you look at the material implementation there are some parts that can be borrowed from the material selecion(is this everything?: https://github.com/FreeCAD/FreeCAD/blob ... _common.py)
This one is also on my short list of relatively easy features(at least if i understand what you meant). But i was also doubting if it would work out to extend this feature that it is also possible to add a custom input field where the corresponding Input deck ... can be added(Basically the calculix name)
Re: FEM improvement
There was a discussion about the implementation of this feature here: https://forum.freecadweb.org/viewtopic.php?f=18&t=60892Jee-Bee wrote: ↑Fri May 06, 2022 3:21 pm I have a few times thought about implementing this feature. But my main problem is that i have only one time and to many thinks i want to do. I think(i'm not sure) that if you look at the material implementation there are some parts that can be borrowed from the material selecion(is this everything?: https://github.com/FreeCAD/FreeCAD/blob ... _common.py)
In terms of CalculiX syntax, we just have to provide a node set or element set (those are already used by other features) plus a reference point. The latter can be a bit more problematic but I suggested a solution that minimizes the necessary changes (see a scheme of rigid body constraint GUI attached to one of the posts in the linked forum thread).
Theoretically, there is a feature to define node sets but I'm not sure if it works correctly. And even if it does, it's far from user-friendliness I would expect in this case. I admit that with current (highly limited) selection tools in FreeCAD it can be difficult to make a simple tool for node set creation. Still, I think that we could make it simpler.Jee-Bee wrote: ↑Fri May 06, 2022 3:21 pm This one is also on my short list of relatively easy features(at least if i understand what you meant). But i was also doubting if it would work out to extend this feature that it is also possible to add a custom input field where the corresponding Input deck ... can be added(Basically the calculix name)
There's no tool for element set creation so this is also on the list of important missing features.
