FEM pipeline graph issue
Moderator: bernd
user1234
Post by user1234 »
Hello!
I had a RL FEM object today and wanted to doublecheck it with FEM, then a saw that the result in the pipeline graph does not match in its magnitude, but at matches in the normal result view graph. It looks like it is N/m², not N/mm² (or MPa).
mwe.FCStd
(175.42 KiB) Downloaded 35 times
Disregarding from this, the text is now barely to see, since it is so long. I must adapt the screen extrawide to see the result.
Also two suggestion (past 0.20):
- is it possible to make a unit on the graph (bottom or top), since i get everytime the chills when i see results without units.
- the the pipeline graph its visibility depends on its position of in the tree. For example it is invisibility when it is in a Part Container.
graph_view_visibility.webm
(164.45 KiB) Downloaded 35 times
Greetings
user1234
user1234
Re: FEM pipeline graph issue
Post by user1234 »
Can someone confirm the graph value issue?
Greetings
user1234
Jee-Bee
Post by Jee-Bee »
user1234 wrote: Sat Apr 16, 2022 11:31 am Can someone confirm the graph value issue?
Yes i can confirm that the graph gives another representation than the value from CXX_Results ... thing.
I don't want to say it is wrong but because there is indeed no unit. I agree that it is annoying!
user1234 wrote: Thu Apr 14, 2022 7:11 pm Also two suggestion (past 0.20):
- is it possible to make a unit on the graph (bottom or top), since i get every time the chills when i see results without units.
I want to add two other suggestions. I think i have to tried them discuss before but at that time there was no interest.
  • Another color scheme (the rainbow how you call it worst ever)
  • Ability to set lower and upper limits for the graph. In case of the upper limit also include a color switch. for all nodes that exceed this limit change to the chosen color.
The idea behind the last point is that in the default situation even by a very small force there are parts of the object(s) that are red colored while there is zero risk(Maybe not a problem for the analyst but maybe for a more management like person in a meeting).
- By changing the the upper limit level it is easy to see how well the object(s) perform and or where the object(s) exceed the requested value(example by having durability in mind)
- By changing the lower level it is more easy tho highlight the stress/ displacement /... flow through the object(s)
user1234
Post by user1234 »
Jee-Bee wrote: Wed Apr 20, 2022 9:14 am Yes i can confirm that the graph gives another representation than the value from CXX_Results ... thing.
Since it was always N/mm² (MPa) before and it is common, it is for me a bug/regression.
Anyway, thanks for confirming, it should solved before releasing 0.20stable.
Greetings
user1234
scuj
Post by scuj »
-> Issue/change discussed in this post: https://forum.freecadweb.org/viewtopic.php?f=18&t=68502
