How to adjust the VTK file drawing code in Freecad?
Moderator: bernd
- freecadlzh
I load the same in VTK file in freecad 0.19 and paraview,Loaded the file in freecad through file \ import . And different results are obtained, as shown in the following figure.
I guess it is necessary to adjust the drawing code in freecad, but after one-step tracking, I can't locate the specific drawing code file in freecad. Do you know which drawing code file is? How to adjust the code file of the drawing?
Thanks a lot.
Thanks a lot.
- loadVTK.png (101.39 KiB) Viewed 2178 times
Re: How to adjust the VTK file drawing code in Freecad?
Is it possible to share the vtk file?
- freecadlzh
The file name is : DAHA.vtk
# vtk DataFile Version 4.2
vtk output
ASCII
DATASET UNSTRUCTURED_GRID
POINTS 26 float
10 10 0 10 10 10 10 0 0
10 0 10 0 10 0 0 10 10
0 0 0 0 0 10 0 5 10
5 10 10 10 5 10 5 0 10
0 5 0 5 10 0 10 5 0
5 0 0 10 10 5 0 10 5
10 0 5 0 0 5 5 5 10
5 5 0 5 10 5 5 0 5
10 5 5 0 5 5
CELLS 5 55
10 3 6 5 7 23 25 20 11 19 8
10 5 6 3 0 25 23 20 22 21 24
10 6 4 0 5 12 13 21 25 17 22
10 6 3 0 2 23 24 21 15 18 14
10 1 3 0 5 10 24 16 9 20 22
CELL_TYPES 5
24
24
24
24
24
POINT_DATA 26
FIELD FieldData 20
Displacement 3 26 double
-3.38163e-06 2.57532e-05 7.89095e-05 -4.65403e-06 -3.60828e-05 9.414e-05 0 0 0
0 0 0 3.46959e-06 2.54436e-05 7.52494e-05 3.98424e-06 -3.85675e-05 9.75419e-05
0 0 0 0 0 0 1.49163e-06 -2.06878e-05 5.88075e-05
9.45592e-07 -3.67725e-05 9.5927e-05 -9.36444e-07 -2.47068e-05 5.65302e-05 0 0 0
3.96268e-06 1.9454e-05 4.22077e-05 1.27912e-06 2.48282e-05 7.71571e-05 -5.18886e-06 1.70879e-05 4.12587e-05
0 0 0 -4.46967e-06 -3.57666e-06 8.1669e-05 3.13775e-06 -5.10807e-06 8.12117e-05
0 0 0 0 0 0 -4.75349e-07 -2.15076e-05 5.78348e-05
-1.01888e-06 1.586e-05 4.33475e-05 8.62431e-07 -5.60747e-06 8.34745e-05 0 0 0
-2.21863e-06 -2.43359e-07 4.02675e-05 3.09224e-06 -1.36144e-06 4.09289e-05
Displacement%20Magnitude 1 26 double
8.3074496218e-05 0.00010092555698 0 0 7.9510295158e-05 0.00010496546327 0 0 6.2358095586e-05
0.00010273801745 6.1700619167e-05 0 4.6643872996e-05 8.1063516724e-05 4.4957768185e-05 0 8.1869383824e-05 8.1432659732e-05
0 0 6.1706295509e-05 4.6169074852e-05 8.3667076304e-05 0 4.0329308188e-05 4.1068118076e-05
Tresca%20Stress 1 26 double
0.0029466441697 0.0055745840716 0.010291014091 0.012669214789 0.00095758453928 0.0088701055865 0.0098015403789 0.015241979552 0.010012013212
0.0055498105641 0.0094682324912 0.015101181055 0.0056047357041 0.0012053214372 0.0055210882825 0.010458893288 0.0030857150668 0.004718479539
0.0089887305451 0.010772663244 0.0099362355191 0.0058515219134 0.0032488796934 0.0097071974165 0.0058503329176 0.0043290408786
Strain%20xx%20component 1 26 double
-1.20916e-06 -1.37602e-06 4.54715e-12 1.74761e-07 -1.91059e-07 -5.83249e-07 -4.40353e-07 2.14489e-12 -3.93394e-07
-8.63821e-07 -3.4831e-07 2.14489e-12 -7.49276e-07 -6.85115e-07 -8.33993e-07 4.54715e-12 -1.32251e-06 -2.08028e-07
4.54715e-12 2.14489e-12 -2.34826e-07 -8.88173e-07 -7.85808e-07 -7.23781e-08 -4.9307e-07 -6.23798e-07
Strain%20xy%20component 1 26 double
3.1766e-07 -4.97119e-07 -8.68691e-07 -2.63415e-07 -4.10658e-07 1.22139e-07 1.43929e-07 9.91131e-08 1.17233e-07
1.27271e-07 -6.07896e-07 -9.75849e-08 -2.62941e-07 2.24942e-08 -4.62975e-08 -4.51692e-07 -2.16348e-07 -3.45199e-07
-5.71667e-07 2.59175e-07 -1.78668e-09 2.27117e-07 1.41292e-07 5.9326e-08 9.26967e-09 5.78843e-08
Strain%20xz%20component 1 26 double
-7.21772e-08 -1.6056e-07 -4.80596e-13 -2.67877e-07 1.06429e-07 8.66947e-08 1.94943e-07 1.40304e-12 -2.57332e-07
-1.1659e-07 3.43344e-08 1.40304e-12 -2.42162e-08 8.24178e-08 8.81461e-08 -4.80596e-13 -2.5278e-07 2.59775e-07
-4.80596e-13 1.40304e-12 -1.89642e-07 1.39344e-07 6.60737e-08 -6.10169e-08 -2.36437e-07 1.99862e-07
Strain%20yy%20component 1 26 double
1.43881e-06 -9.42096e-07 4.25981e-06 -4.35071e-06 -1.48542e-07 -3.36407e-06 3.96464e-06 -4.41834e-06 -3.85673e-06
-1.71988e-06 -3.60827e-06 -4.5823e-06 2.54435e-06 4.4718e-07 2.57531e-06 4.01424e-06 6.66444e-07 -2.09578e-06
7.93561e-07 -5.53071e-07 -4.0239e-06 2.6711e-06 -8.82788e-07 -8.45158e-08 -1.32404e-06 1.88548e-07
Strain%20yz%20component 1 26 double
3.39393e-07 -5.9448e-07 4.30624e-06 5.11912e-06 -6.3912e-08 -7.77964e-08 3.91284e-06 6.88437e-06 2.94442e-06
-4.12123e-07 2.10183e-06 6.7871e-06 1.8263e-06 2.4473e-08 2.21232e-06 4.51511e-06 1.02315e-07 3.69421e-07
4.20712e-06 5.09651e-06 2.54243e-06 2.1502e-06 3.20587e-07 4.6022e-06 2.50523e-06 1.80766e-06
Strain%20zz%20component 1 26 double
-2.88152e-07 3.46532e-06 1.08083e-12 1.89095e-06 1.55687e-07 5.04379e-06 -1.03903e-06 -1.94957e-11 3.57571e-06
3.46162e-06 4.22365e-06 -1.94957e-11 -1.29254e-06 2.26713e-07 -1.98234e-07 1.08083e-12 1.52303e-06 2.22924e-06
1.08083e-12 -1.94957e-11 3.90602e-06 -8.14908e-07 2.0446e-06 1.94405e-07 1.01891e-06 2.09352e-06
Stress%20xx%20component 1 26 double
-0.00276741 0.00138633 0.0159179 -0.00817012 -0.00108997 0.00286783 0.00835857 -0.0165103 -0.00334937
0.00145972 0.000263796 -0.017123 0.000298469 -0.0014861 0.00400813 0.0150003 0.000451874 -0.00071713
0.00296537 -0.00206675 -0.00181296 0.00174506 -0.000251387 -1.23954e-05 -0.00402204 0.00488164
Stress%20xy%20component 1 26 double
0.0006696 -0.00104788 -0.00183112 -0.000555256 -0.000865631 0.000257459 0.000303391 0.000208922 0.000247116
0.000268277 -0.00128139 -0.000205701 -0.000554257 4.74158e-05 -9.75911e-05 -0.000952127 -0.000456043 -0.000727649
-0.00120502 0.000546318 -3.76616e-06 0.000478742 0.000297831 0.000125054 1.95397e-05 0.000122015
Stress%20xz%20component 1 26 double
-0.000152143 -0.000338446 -1.01306e-09 -0.000564661 0.000224343 0.000182745 0.000410924 2.95749e-09 -0.000542433
-0.000245762 7.23739e-05 2.95749e-09 -5.10457e-05 0.00017373 0.000185804 -1.01306e-09 -0.000532839 0.000547583
-1.01306e-09 2.95749e-09 -0.000399748 0.000293725 0.000139278 -0.000128618 -0.00049839 0.000421292
Stress%20yy%20component 1 26 double
0.00281427 0.002301 0.0248972 -0.0177094 -0.00100035 -0.0029939 0.0176439 -0.0258238 -0.0106498
-0.00034478 -0.00660791 -0.0267821 0.00724116 0.000900683 0.0111946 0.0234619 0.00464442 -0.00469635
0.00463812 -0.00323258 -0.0098 0.00924771 -0.000455813 -3.79806e-05 -0.00577366 0.00659399
Stress%20yz%20component 1 26 double
0.000715411 -0.00125311 0.00907717 0.0107907 -0.000134721 -0.000163988 0.00824793 0.0145117 0.00620658
-0.00086872 0.00443047 0.0143066 0.00384969 5.1587e-05 0.00466338 0.00951747 0.000215671 0.000778708
0.00886824 0.010743 0.00535921 0.00453243 0.00067577 0.00970104 0.00528081 0.00381039
Stress%20zz%20component 1 26 double
-0.000826013 0.0115915 0.0159179 -0.00455255 -0.000359064 0.0147291 0.00709661 -0.0165104 0.00501715
0.0105774 0.0099011 -0.017123 -0.000846675 0.000435959 0.00534825 0.0150003 0.00645003 0.00442043
0.00296537 -0.0020668 0.0069156 0.0018995 0.00571487 0.000549961 -0.00083492 0.0106095
Major%20Principal%20Stress 1 26 double
0.0030185479728 0.011761370729 0.030698564287 0.0015668507617 2.000003911e-09 0.014733359487 0.022175577927 -0.0059251203947 0.007195554208
0.010653772338 0.011020439947 -0.0068513689876 0.0088139992365 0.00090820974203 0.013775249917 0.029689993389 0.0065319864843 0.0045316724657
0.01279047568 0.0081229734581 0.0085005898183 0.011440333101 0.0057928292139 0.0099614860292 0.002550953579 0.012931045491
Intermediate%20Principal%20Stress 1 26 double
-0.00092296060635 0.0029052566846 0.015917899607 -0.0082273419459 -0.00053421892146 0.0028765221981 0.0083510049043 -0.016510300106 -0.0033491019921
0.0014844164516 0.00045257108811 -0.017122999915 0.00027442693515 0.00044476539036 0.0040426567311 0.015000299799 0.004653781165 -0.00061943585348
0.0029653697297 -0.002066750429 -0.0018260685984 0.001714647625 -8.0229040981e-05 -8.9922255294e-06 -0.0040318613228 0.0048811207752
Minor%20Principal%20Stress 1 26 double
-0.0028747403665 0.00061220258608 0.010116536105 -0.023771578816 -0.0019151670785 -0.0030068516855 0.0025724971689 -0.036409079499 -0.012828472216
-0.00044584878992 -0.0079160250352 -0.037053731097 -0.0023954721716 -0.0015024331324 0.0027330733519 0.008772206812 0.00036055635066 -0.0049052866122
-0.0051869854099 -0.013422353029 -0.01137188122 -0.00026271072591 -0.00070493017292 -0.0094529088037 -0.0091497122562 0.0042729637338
UserDefinedMyName 1 26 double
0.0058932883393 0.011149168143 0.020582028182 0.025338429577 0.0019151690786 0.017740211173 0.019603080758 0.030483959105 0.020024026424
0.011099621128 0.018936464982 0.03020236211 0.011209471408 0.0024106428744 0.011042176565 0.020917786577 0.0061714301337 0.0094369590779
0.01797746109 0.021545326487 0.019872471038 0.011703043827 0.0064977593868 0.019414394833 0.011700665835 0.0086580817572
von%20Mises%20Stress 1 26 double
0.0051997971865 0.010197862603 0.018381291453 0.022131262098 0.001711765522 0.015651098543 0.01744693019 0.026807454314 0.017349493774
0.010271431265 0.016436285458 0.026598149601 0.010141619831 0.00221557688 0.010449115801 0.018602822841 0.0054793240652 0.0081840891454
0.015591387182 0.018667903963 0.0172144927 0.010850348816 0.0062090233458 0.016815420359 0.010159513551 0.0083705890662
You can add a zip file.freecadlzh wrote: ↑Thu Jan 27, 2022 12:01 am In forum, I can not share the .vtk file, so I copy the file content above. Please plaste the data into a file, and name the file to .vtk file, then can use it . Thanks a lot.
- freecadlzh
chrisb wrote: ↑Thu Jan 27, 2022 6:16 amYou can add a zip file.freecadlzh wrote: ↑Thu Jan 27, 2022 12:01 am In forum, I can not share the .vtk file, so I copy the file content above. Please plaste the data into a file, and name the file to .vtk file, then can use it . Thanks a lot.
When I load the file then I can choose between two options:
- load as FEM result VTK file
- load as FEM mesh file
When loading as result object I get the same visual representation as the OP but loading as mesh shows the cube.Warning: In /build/vtk7-w4DzBd/vtk7-7.1.1+dfsg1/IO/Legacy/vtkDataReader.cxx, line 490
vtkDataSetReader (0x49063d0): Reading file version: 4.2 with older reader version 4.1
When I copy & paste the content inside the code tags then loading the VTK file as mesh causes a segmentation fault. The problem is the empty first line.
This is fixed with: git commit 7ef448572d
After removing this line it works to load as mesh file (but still not as result file).
When loading as result object then this is the code line where it happens: https://github.com/FreeCAD/FreeCAD/blob ... e.cpp#L150
The entry point to update the visual representation is: https://github.com/FreeCAD/FreeCAD/blob ... ne.cpp#L62
After having loaded the file then the default display mode is set to Outline and that's why you get what you see. So, in the property editor under View change the display mode to e.g. Surface which shows you a blue cube. Afterwards you can change the Field property to set the colouring.
