FEA example frame
Moderator: bernd
thschrader
Re: FEA example frame
Post by thschrader »
cad1234 wrote: Wed Oct 06, 2021 9:03 pm ...
If you have time and (maybe) muse, could you give a few words about this?
I mean this. A fresh project. 15-m-Antennmast, red=omni-antenna and lightning-protection.
The n1x formula is a more ore less good guess, because in this case the stiffness/mass of the
omni/lightning-protection is unknown.
cad1234
Post by cad1234 »
thschrader wrote: Thu Oct 07, 2021 6:45 am
MANY THANKS!!!
Will work through it step by step, to understand...will be a big step forward for me..
zergamat
Post by zergamat »
Photo after HDG.
zergamat
Post by zergamat »
Frame after installation. I know that photos are poor.
Frame (5).jpg (45.67 KiB) Viewed 1941 times
Frame (4).jpg (293.43 KiB) Viewed 1941 times
Frame (3).jpg (101.65 KiB) Viewed 1941 times
Frame (2).jpg (102.4 KiB) Viewed 1941 times
Frame (1).jpg (87.13 KiB) Viewed 1941 times
NewJoker
Post by NewJoker »
Looks great :-) Was the frame's geometry designed entirely in FreeCAD or imported from external CAD software and only analyzed in FreeCAD with its FEM module ? What about the technical drawings - which software did you use to create them ?
thschrader
Yeah, impressive work!
Is it this tower?
https://de.wikipedia.org/wiki/Sendemast_Krynice
zergamat
Post by zergamat »
Freecad FEA was done mostly for fun and to check this great software. It was drawn entirely in FreeCad. I wasn't able to import anything with good results (unfortunately). Technical drawings was done in basic cad software (ZwCAD).
NewJoker
Post by NewJoker »
zergamat wrote: Wed Jan 05, 2022 9:57 am Technical drawings was done in basic cad software (ZwCAD).
FreeCAD also has a decent module for 2D documentation (TechDraw), did you give it a try ? It could be sufficient in your case.
Can you tell us where this tower is located ? Is it actually in Poland as we suspect ? I could see it one day since I live in this country ;-)
