FEA example frame
Moderator: bernd
zergamat
FEA example frame
Post by zergamat »
Hello everyone
I would like to share the FEM of the steel frame we did some time ago. Did it in freecade for fun.
Nonlinear material.
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
VonMises (1).jpg (96.7 KiB) Viewed 5207 times
deformation (2).jpg (267.11 KiB) Viewed 5207 times
deformation (1).jpg (278.01 KiB) Viewed 5207 times
VonMises (2).jpg (72.01 KiB) Viewed 5207 times
bernd
Re: FEA example frame
Post by bernd »
looks cool
How big is it? What is the frame for? What material is the frame made of? Does it exists in real?
bernd
zergamat
Post by zergamat »
It is almost ready.
About 1400mm in axis and 700mm height, ~1500kg. Made from S355J2.
Maybe will be able to put some photos in couple of weeks. It is element between 300m mast and 20m+ antena.
Results from Freecad are more or less we were expecting.
Great software.
photo (2).jpg (104.98 KiB) Viewed 5006 times
photo (1).jpg (151.43 KiB) Viewed 5006 times
M4x
Post by M4x »
Looks good, thanks for sharing! Did you create technical drawings too? How did you deal with the welding seams (regarding FEM)?
zergamat
Post by zergamat »
Yes. I did all documentation from concept to technical drawings for workshop (we use basic Cad software).
I'm not sure what do you meen about welding. Welds were calculated according to eurocodes. Most of them are full penetration joints (they are dynamically loaded and stress is high). They are not included in FEM (I have very little experience in FEM, but in this model it wolud not do any good?).
thschrader
Post by thschrader »
zergamat wrote: Wed Oct 06, 2021 10:29 am ...
Great job, keep going.
Weldings:
I never model weldings in FC-FEM. Your model gets far too complicated and you run into
a lot of trouble with meshing/meshrefinement.
We mostly use S235J2, so you can utilize the weldings up to 36 kN/cm^2. No problem.
Dynamic loading:
We calculate the first eigenfrequency via statics/deformation. Thats enough to
specify the windgust-factor at full loading.
Karman-vortex excitation:
You can do the calculation, but it makes no sense because of the cables/ladder.
No vortex possible.
Greetings Thomas
M4x
Post by M4x »
thschrader explained in the German subforum that the welding joints may be important in dynamic load situations. This is the thread: https://forum.freecadweb.org/viewtopic. ... 4&start=60
I've put the translation directly into the quoted content (translated via deepl.com).
thschrader wrote: Mon Aug 16, 2021 9:59 am
chrisb wrote: Mon Aug 16, 2021 8:37 am Können Schweißnähte eigentlich gesondert behandelt werden? Das Material verhält sich dort ja eher anders.
translation
Can weld seams actually be treated separately? The material tends to behave differently there.
Kommt drauf an.
Bei rein statischer Belastung kannst du die Festigkeiten der Naht im Grunde wie die Bauteilfestigkeit ansetzen.
Bei dynamischer Belastung sieht das anders aus, z.B. bei Brücken, Kranbahnen, Achterbahnen usw.
Die zulässigen Spannungen in der Naht müssen dann teilweise erheblich abgemindert werden,
siehe "Wöhlerlinie" und "Kerbfall".
translation
It depends.
For purely static loads, you can basically use the strength of the weld as the strength of the component.
The situation is different for dynamic loads, e.g. bridges, crane runways, roller coasters, etc.
The permissible stresses in the weld must then be reduced considerably in some cases,
see "Wöhler line" and "notch drop".
edit
Now thschrader was faster than me :)
twangrt
Post by twangrt »
zergamat wrote: Tue Oct 05, 2021 6:48 am It is almost ready.
Great software.
Damn, really nice of you to share this. I don't want to share anything I designed, it's a mental barrier :D
M4x
Post by M4x »
Please tear it down ;)
cad1234
Post by cad1234 »
thschrader wrote: Wed Oct 06, 2021 3:48 pm Dynamic loading:
@Thomas
If you have time and (maybe) muse, could you give a few words about this?
..your posts trigger my greed to learn and understand more....
