gmsh fails on simple cube
Moderator: bernd
wingman
Post by wingman »
# dnf list freecad
freecad.x86_64 1:0.19.2-1.fc34
OS: Fedora 34 (Workstation Edition) (KDE/plasmax11)
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.9.4
Qt version: 5.15.2
OCC version: 7.5.0
I'm using the gmsh included with FreeCAD. If I install gmsh on my computer and try gmsh from within FreeCAD, the program crashes without any warning.
# dnf list gmsh
Available Packages
gmsh.x86_64 4.7.1-2.fc34
Steps to reproduce:
New file
New part
New body
Select Part Design workbench
Draw a cube
Select FEM
Select New Analysis
Select Material. Select a steel, select the cube as a body.
Set force constraints on the cube, or not
Select a face of the cube
Select GMesh Icon
Select From Shape
Max, Min element sizes = 0.0
Select Apply
The FreeCAD source file is attached below.
In the Gmsh Task window:
0.0: We are going to start ...
0.0: Start Gmsh ...
0.0: Gmsh had warnings ...
0.0: Error executing: gmsh - /tmp/fcfem_j83785sd/shape2mesh.geo
0.0: Gmsh done!
In Report View:
13:03:52  Active analysis found: Analysis
13:03:56  Active analysis found: Analysis
13:03:56    ElementDimension: 3
13:03:56    [b]No Group meshing for analysis.[/b]
13:03:56    /tmp/fcfem_j83785sd/Box_Geometry.brep
13:03:56    /tmp/fcfem_j83785sd/Box_Mesh.unv
13:03:56    /tmp/fcfem_j83785sd/shape2mesh.geo
13:03:56    gmsh
13:03:56  Error executing: gmsh - /tmp/fcfem_j83785sd/shape2mesh.geo
13:03:56  No mesh was created.
13:03:56  Gmsh had warnings ...
/tmp/fcfem_j83785sd/shape2mesh.geo:
/ geo file for meshing with Gmsh meshing software created by FreeCAD
// open brep geometry
Merge "/tmp/fcfem_j83785sd/Box_Geometry.brep";
// Characteristic Length
// no boundary layer settings for this mesh
// min, max Characteristic Length
Mesh.CharacteristicLengthMax = 1e+22;
Mesh.CharacteristicLengthMin = 0.0;
// optimize the mesh
Mesh.Optimize = 1;
Mesh.OptimizeNetgen = 0;
Mesh.HighOrderOptimize = 0;  // for more HighOrderOptimize parameter check http://gmsh.i>
// mesh order
Mesh.ElementOrder = 2;
Mesh.SecondOrderLinear = 0; // Second order nodes are created by linear interpolation in>
// mesh algorithm, only a few algorithms are usable with 3D boundary layer generation
// 2D mesh algorithm (1=MeshAdapt, 2=Automatic, 5=Delaunay, 6=Frontal, 7=BAMG, 8=DelQuad)
Mesh.Algorithm = 2;
// 3D mesh algorithm (1=Delaunay, 2=New Delaunay, 4=Frontal, 5=Frontal Delaunay, 6=Front>
Mesh.Algorithm3D = 1;
// meshing
Geometry.Tolerance = 1e-06; // set geometrical tolerance (also used for merging nodes)
Mesh  3;
Coherence Mesh; // Remove duplicate vertices
// save
Mesh.Format = 2;
// Ignore Physical definitions and save all elements;
Mesh.SaveAll = 1;
Save "/tmp/fcfem_j83785sd/Box_Mesh.unv";
// Gmsh documentation:
// http://gmsh.info/doc/texinfo/gmsh.html#Mesh
// We do not check if something went wrong, like negative jacobians etc. You can run Gms>
// to see full Gmsh log, run in bash:
// gmsh - /tmp/fcfem_j83785sd/shape2mesh.geo
// to run Gmsh and keep file in Gmsh GUI (with log), run in bash:
// gmsh /tmp/fcfem_j83785sd/shape2mesh.geo
FEM Test.FCStd
(8.8 KiB) Downloaded 81 times
Laurie Hartley
Re: gmsh fails on simple cube. Linux, FreeCAD-0.19...
Post by Laurie Hartley »
wingman wrote: Mon Sep 27, 2021 8:54 pm I'm using the gmsh included with FreeCAD. If I install gmsh on my computer and try gmsh from within FreeCAD, the program crashes without any warning.
Hello Wingman - you probably should have started a separate thread to find a solution to your problem. Bernd may well do that for you. However in the meantime I had a similar issue on my new Linux laptop so perhaps you may find this thread and the solution achieved useful:
https://forum.freecadweb.org/viewtopic. ... 98#p522998
wingman
Re: Request for help meshing and and analysing a part
Post by wingman »
Thanks for the advice and link, Laurie. I'll test using an external gmsh and report what transpires.
wingman
Post by wingman »
I installed gmsh on my computer.
$ gmsh --version
4.7.1
$which gmsh
/usr/bin/gmsh
I installed the path into Edit->Preferences->FEM->Gmsh->binary path and deselected Search in known binary directories.
Good news: FreeCAD doesn't crash anymore.
Bad news: it doesn't generate a mesh
Good news: it returns a different warning in Report View:
16:26:45  Active analysis found: Analysis
16:26:47  Active analysis found: Analysis
16:26:47    ElementDimension: 3
16:26:47    Group meshing for analysis is set to true in FEM General Preferences. Are you really sure about this? You could run into trouble!
16:26:47    {'MaterialSolid': ['Solid1']}
16:26:47    /tmp/fcfem_inkyjvun/Box_Geometry.brep
16:26:47    /tmp/fcfem_inkyjvun/Box_Mesh.unv
16:26:47    /tmp/fcfem_inkyjvun/shape2mesh.geo
16:26:47    /usr/bin/gmsh
16:26:47  Error executing: /usr/bin/gmsh
 - /tmp/fcfem_inkyjvun/shape2mesh.geo
16:26:47  No mesh was created.
16:26:47  Gmsh had warnings ...
Where does one set the group meshing option ?
In Model->Analysis -> FEMMeshGmsh->Data there is a field named Mesh Group List. Right now it is blank. If I press the ... button, objects appear. Also note that Fem Mesh says 0 nodes, edges... groups.
Is this a user error, a FreeCAD error or a gmsh error ?
wingman
problems with gmsh
Post by wingman »
I installed gmsh-4.8.4 from the gmsh website.
When I run it, I receive the following in Report View
16:41:10  Active analysis found: Analysis
16:41:10    ElementDimension: 3
16:41:10    Group meshing for analysis is set to true in FEM General Preferences. Are you really sure about this? You could run into trouble!
16:41:10    {'MaterialSolid': ['Solid1']}
16:41:10    /tmp/fcfem_hi8tn67s/Box_Geometry.brep
16:41:10    /tmp/fcfem_hi8tn67s/Box_Mesh.unv
16:41:10    /tmp/fcfem_hi8tn67s/shape2mesh.geo
16:41:10    /home/me/Downloads/gmsh-4.8.4-Linux64/bin/
16:41:10  Error executing: /home/me/Downloads/gmsh-4.8.4-Linux64/bin/ - /tmp/fcfem_hi8tn67s/shape2mesh.geo
16:41:10  No mesh was created.
16:41:10  Gmsh had warnings ...
In Edit->Preferences->FEM-General, the Create mesh groups for analysis reference shapes (highly experimental) option is both checked and greyed out. I cannot un check it.
-alex-
Post by -alex- »
Laurie Hartley wrote: Mon Sep 27, 2021 9:38 pm Hello Wingman - you probably should have started a separate thread to find a solution to your problem.
+1
@Wingman, please do not hijack this thread.
wingman
Post by wingman »
I'll move my posts later tonight. I thought this was the appropriate thread.
bernd
Post by bernd »
I moved all your posts in a separate topic.
Would you use code tags for long log prints in a post? like this .... https://forum.freecadweb.org/viewtopic. ... 20#p517783
Laurie Hartley
Re: problems with gmsh
wingman wrote: Mon Sep 27, 2021 10:43 pm I installed gmsh-4.8.4 from the gmsh website.
Have you tried copying the download file into your opt folder, and extracting it there.
“Copied and extracted it into the opt folder.
Set the path in FEM - Gmsh preferences to /opt/gmsh-4.8.4-Linux64/bin/gmsh.”
wingman
Post by wingman »
bernd wrote: Tue Sep 28, 2021 9:48 am I moved all your posts in a separate topic.
Thank you. Sorry, I got busy with another part of the project.
OK.
