[solved] Can't run buckling analysis in 0.20
Moderator: bernd
NewJoker
Post by NewJoker »
previously, when I was trying to submit the analysis in 0.20, I was receiving "No CalculiX binary ccx" error each time: https://forum.freecadweb.org/viewtopic.php?f=18&t=60951
Now in the newest weekly build there's no such issue but I can't run buckling analysis successfully and it happens on 2 different computers. There's no pop-up window with error message, just some red-colored output in the Report View:
and FreeCAD hangs completely (I have to kill it with Task Manager).
I also tried running this type of analysis with "Solver CalculiX (new framework) and it completes but the results seem empty.
Version: 0.20.25541 (Git)
Hash: ca043dcb6d20d70b8e24d75e810683214eecc5d4
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
thschrader
Re: Can't run buckling analysis in 0.20
Post by thschrader »
I get this with
beullast_zylinder.FCStd
(14.35 KiB) Downloaded 29 times
OS: Windows 10 Version 1909
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
cad1234
Post by cad1234 »
@Thomas
The same here..
OS: Windows 10 Version 2004
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
bernd
Post by bernd »
cad1234 wrote: Fri Sep 03, 2021 8:11 am @Thomas
The same here..
this is a totally different error not related to buckling at all. You would need to post the file to make us find the problem. But since it is a different problem make a new topic.
bernd
Post by bernd »
NewJoker wrote: Thu Sep 02, 2021 4:26 pm Hi,
it seams this is a problem of the calculix binary and not inside FreeCAD. ccxtools and calculix new solver framework eventually use the same ccx binary. See this topic suggested links.
bernd
Post by bernd »
We should get rid of this. Would you report back if you succeeded with a alternate ccx binary? Which FreeCAD did you download?
cad1234
Post by cad1234 »
bernd wrote: Fri Sep 03, 2021 10:33 am
this was only meant as confirmation about what Thomas wrote, with my local computer..
I used his file beullast_zylinder, started buckling and had the same messages as thomas...
also with "INTEL MKL ERROR: Das angegebene Modul wurde nicht gefunden. mkl_intel_thread.dll. "
and the message about Nodecount
NewJoker
Post by NewJoker »
bernd wrote: Fri Sep 03, 2021 10:38 am We should get rid of this. Would you report back if you succeeded with a alternate ccx binary? Which FreeCAD did you download?
I tried using ccx_PARDISO downloaded from the CalculiX's homepage (newest release), placed in FreeCAD's bin folder and selected in Preferences --> FEM --> CalculiX --> CalculIX binary but I got errors saying: "FEM: wrong ccx binary", "FEM: CalculiX binary ccx ... not found. Please set the CalculiX binary ccx path in FEM preferences tab CalculiX" and "CalculiX has not been run. The CalculiX binary search returned: False.".
To get the newest FreeCAD weekly build I downloaded this file:
https://github.com/FreeCAD/FreeCAD-Bund ... -x86-64.7z
johnwang
Post by johnwang »
Got result with:
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
So, no problem now?
uwestoehr
Post by uwestoehr »
NewJoker wrote: Thu Sep 02, 2021 4:26 pm OS: Windows 10 Version 2009
This is not FreeCAD 0.20.0 final. You must use at least this version.
In your error message you also see that an outdated LibPack was used. This had some issues with third-party libraries like CCX and others.
FC 0.20.1 will come out this week and comes with massive fixes for FEM.
