Explanation:
1. I select the part in the viewport.
2. Click the button "Create a FEM mesh from a shape by Gmsh mesher" (I do have Gmsh installed).
3. Click apply. This message appears in the window:
0.0: We are going to start ...
0.0: Start Gmsh ...
Here is the report:
19:18:17 Active analysis found: Analysis
19:18:17 ElementDimension: 3
19:18:17 Group meshing for analysis is set to true in FEM General Preferences. Are you really sure about this? You could run into trouble!
19:18:17 Empty reference: MaterialSolid
19:18:17 One material with no reference shapes. No need to make a group for materials.
19:18:17 {'ConstraintFixed': ['Face1'], 'ConstraintForce': ['Face2']}
19:18:17 /tmp/fcfem_rujnmida/Box_Geometry.brep
19:18:17 /tmp/fcfem_rujnmida/Box_Mesh.unv
19:18:17 /tmp/fcfem_rujnmida/shape2mesh.geo
19:18:17 /usr/local/bin/gmsh
19:18:17 Unexpected error when creating mesh: <class 'RuntimeError'>
19:18:17 Traceback (most recent call last):
File "/tmp/.mount_FreeCAZvgZl3/usr/Mod/Fem/femtaskpanels/task_mesh_gmsh.py", line 117, in clicked
self.run_gmsh()
File "/tmp/.mount_FreeCAZvgZl3/usr/Mod/Fem/femtaskpanels/task_mesh_gmsh.py", line 210, in run_gmsh
error = sys.exc_info()[0].strip()
<class 'AttributeError'>: type object 'RuntimeError' has no attribute 'strip'
19:18:17 timer2
19:18:17 timer2
19:18:17 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:18 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:19 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:20 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:21 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:22 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:23 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:24 timer2
19:18:25 timer2
19:18:25 timer2
19:18:25 timer2
19:18:25 timer2
19:18:25 timer2
19:18:25 timer2
19:18:25 timer2
19:18:25 Traceback (most recent call last):
19:18:25 File "/tmp/.mount_FreeCAZvgZl3/usr/Mod/Fem/femtaskpanels/task_mesh_gmsh.py", line 151, in update_timer_text
19:18:25 self.form.l_time.setText("Time: {0:4.1f}: ".format(time.time() - self.Start))
19:18:25 AttributeError: 'NoneType' object has no attribute 'l_time'
19:18:25 timer2
19:18:25 timer2
