Implemented Gmsh Mesh Property "MeshSizeFromCurvature"
Moderator: bernd
UR_
Post by UR_ »
This topic was shortly raised at https://forum.freecadweb.org/viewtopic. ... re#p454459
Now Gmsh 4.8.0 is out!
MeshSizeFromCurvature has changed
 Mesh.MinimumElementsPerTwoPi = 12;
is no more necessary.
So I implemented new API. (Please update your gmsh.exe before testing)
Screenshot 004.png (6.95 KiB) Viewed 3122 times
To shape2mesh.geo following line will be added:
Mesh.MeshSizeFromCurvature = 12; // number of elements per 2*pi radians, 0 to deactivate
And these are the differences shown up:
MeshSizeFromCurvature ON OFF.png (872.32 KiB) Viewed 3122 times
PR: https://github.com/FreeCAD/FreeCAD/pull/4596
bernd
Re: Implemented Gmsh Mesh Property "MeshSizeFromCurvature"
Post by bernd »
wow this is what netgen is able to do and what makes netgen meshes better cimpored to gmsh in a lot of cases.
We need it to make in a way it workes the old way too for people without the new gmsh binary too.
UR_
Post by UR_ »
ATM, I'm working on a button in gmsh mesh task panel obtaining gmsh's version info and outputting it to a message box and a copy to report view.
Perhaps function can be used to distinguish between version 4.8.0 and lower ones.
user1234
Post by user1234 »
Sounds nice! But on shaft objects the result is pretty bad.
Here is a rectangle shaft with some radius on it.
In general i have seen, that gmsh has serious issues with shafts.
Greetings
user1234
bernd
Post by bernd »
user1234 wrote: Sun Mar 07, 2021 7:16 pm Sounds nice! But on shaft objects the result is pretty bad.
How about the geometry as file?
user1234
Post by user1234 »
Sorry, i never saved that. I made a new similar.
Default settings with cleared mesh. You can clearly see where the seam is. Attention: when you run this with gmsh, this will take a while (195MByte). I use gmsh-4.8.0 and the PR-branch https://github.com/FreeCAD/FreeCAD/pull/4596.
OS: Debian GNU/Linux bullseye/sid (X-Cinnamon/lightdm-xsession)
Version: 0.20.Unknown
Build type: Debug
Python version: 3.9.1+
Qt version: 5.15.2
OCC version: 7.5.1
test23_gmsh_curviate.FCStd
(27.56 KiB) Downloaded 52 times
Greetings
user1234
UR_
Post by UR_ »
Gmsh and netgen have a two different approaches regarding growth of mesh sizes between edg#es.
For example taking a simple cylinder with a circle shaped bottom and a top edge.
Lets say that mesh at edges is finer than defined max. mesh size.
While netgen uses a input value called growth to enlarge mesh size from outer edges to center of face,
gmesh lets grow mesh only between edges with different mesh sizes.
So you have to place a third circle in the middle (without refined mesh) to let gmsh calculate it's growth rate.
Screenshot 002.png (166.48 KiB) Viewed 2910 times
shaft.FCStd
(28.37 KiB) Downloaded 296 times
user1234
Post by user1234 »
Hello!
UR_ wrote: Mon Mar 08, 2021 4:39 pmSo you have to place a third circle in the middle (without refined mesh) to let gmsh calculate it's growth rate.
With that knowledge, now also mesh region on shaft works correctly. Before that, it never worked correct. Many, many thanks! This saves me hours of work per shaft analysis! Before that is was more or less try and error.
Greetings
user1234
Jee-Bee
Post by Jee-Bee »
Can we request a growth option to the GMSH team?
bernd
Post by bernd »
