FEM_FrontISTR: A parallel nonlinear finite element analysis workbench for FreeCAD
Moderator: bernd
thschrader
Re: FEM_FrontISTR: A parallel nonlinear finite element analysis workbench for FreeCAD
Post by thschrader »
Seems to be a bug. Same error happens here...
Just updatet FrontISTR-wb and solver.
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Eneen
Post by Eneen »
Looks like it's working in 19.3 so most likely plugin needs an update.
And it's so extremely fast: besides super fast calculations exporting input file takes couple of seconds.
thschrader
Just updated FEMFronstISTR-wb and solvers:
error-message when writing inp-file
11:16:40  Traceback (most recent call last):
11:16:40    File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\FEM_FrontISTR\task_solver_fistrtools.py", line 326, in write_input_file_handler
11:16:40      if self.check_prerequisites_helper():
11:16:40    File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\FEM_FrontISTR\task_solver_fistrtools.py", line 366, in check_prerequisites_helper
11:16:40      message = self.fea.check_prerequisites()
11:16:40    File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\FEM_FrontISTR\fistrtools.py", line 260, in check_prerequisites
11:16:40      from femtools.checksanalysis import check_analysismember
11:16:40  ImportError: cannot import name 'check_analysismember' from 'femtools.checksanalysis' (C:\GA-NT\Anwendungen\TS_513538\FreeCAD\FreeCAD_0.20.27428_Win-LPv12.5.4_vc17.x-x86-64\Mod\Fem\femtools\checksanalysis.py)
Done with:
Version: 0.20.27428 (Git)
Hash: 27460358508a2057e0ec57a418641435f12628dd
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Heads up: FEM_FrontISTR also needs a package.xml file
https://github.com/FrontISTR/FEM_FrontISTR/issues/3
samudge
Post by samudge »
thschrader wrote: Sun Mar 20, 2022 10:22 am Just updated FEMFronstISTR-wb and solvers:
I fixed this issue (at least it now works for me, after experiencing this same issue) with this PR:
https://github.com/FrontISTR/FEM_FrontISTR/pull/11
It has not been merged as of right now, so you can clone or checkout my fork if you want to use FrontISTR with FreeCAD 0.20
thschrader
samudge wrote: Sun Jul 31, 2022 1:25 am ... or checkout my fork if you want to use FrontISTR with FreeCAD 0.20
Sorry for the late reply, heavy workload in the office...
I updated the FEM_FrontISTR-wb (workbench + solver, latest MSMPI) via
https://www.frontistr.com/download/
Writing input file, editing, running solver works.
But our Symantec Endpoint Protection kills the hecmw_part1.exe file.
The solver stopps with error. When looking into "Mod/FEM_FrontISTR/bin" folder, the file is deleted after solver run.
It seems I have to call our IT... :roll:
Our is there a workaround?
Solver "error":
0.0: Check dependencies...
2.4: Writing .inp file and partitioning completed.
0.0: FrontISTR binary: C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod/FEM_FrontISTR/bin/fistr1.exe
0.0: Run FrontISTR...
0.0: Starting FrontISTR...
0.0: FrontISTR is running...
1.4: FrontISTR stopped.
1.4: FrontISTR stdout:
job aborted:
[ranks] message
[0] application aborted
aborting (comm=0x84000000), error 40958680, comm rank 0
[1] application aborted
aborting (comm=0x84000000), error 40958680, comm rank 1
[2] application aborted
aborting (comm=0x84000000), error 40958680, comm rank 2
[3] application aborted
aborting (comm=0x84000000), error 40958680, comm rank 3
---- error analysis -----
[0-3] on ANDEGF001NB1032
C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod/FEM_FrontISTR/bin/fistr1.exe aborted the job. abort code 40958680
1.4: FrontISTR execute error:
1.5: Loading result sets...
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
  * BIM
  * CfdOF 1.17.6
  * Curves 0.3.0
  * Defeaturing_WB
  * dodo
  * Fasteners
  * FEM_FrontISTR 0.1.0
  * Manipulator 1.4.3
  * Plot
  * Reinforcement
  * WorkFeature
psg.lgd.fy
Post by psg.lgd.fy »
Kunda1 wrote: Sun Mar 20, 2022 3:25 pm Heads up: FEM_FrontISTR also needs a package.xml file
Hello, how to use this xml file. I have put the solver in the bin directory of frontlstr.
windows10
freecad0.21
xml lives in the top level directory per Package_Metadata specs
