FEM_FrontISTR: A parallel nonlinear finite element analysis workbench for FreeCAD
Moderator: bernd
Found on gitlab (im not the author)
FEM_FrontISTR is a FreeCAD addon that enables a parallel nonliner FEM solver FrontISTR.
FrontISTR(japanese web site): https://www.frontistr.com/
Repo: https://gitlab.com/FrontISTR-Commons/FEM_FrontISTR
twangrt
Re: FEM_FrontISTR: A parallel nonlinear finite element analysis workbench for FreeCAD
Post by twangrt »
Cool, but someone more educated must enlighten me about "parallel finite element analysis".
Found this: https://www.sciencedirect.com/science/a ... 499090211J
I searched the FrontISTR english manual, and found only one tutorial labeled "Linear static analysis, Parallel". Seems it divides the calculation in to X separate calculations. Which is neat, but does it save computing time on a single computer?
https://manual.frontistr.com/en/tutoria ... al_02.html
bernd
Post by bernd »
Wow, seams Japanese.
johnwang
Post by johnwang »
twangrt wrote: Sun Feb 07, 2021 7:41 pm separate calculations. Which is neat, but does it save computing time on a single computer?
Single computer with multi cores, if you manage well, it should faster than single core.
twangrt
Post by twangrt »
johnwang wrote: Wed Feb 10, 2021 12:04 pm Single computer with multi cores, if you manage well, it should faster than single core.
Yes, of course. But most solvers are using multithreading, I thought "parallel" was a more unique method.
johnwang
Post by johnwang »
tutorials
https://manual.frontistr.com/en/tutorial/index.html
tutorial/01_elastic_Hinge
johnwang
Post by johnwang »
tutorial/06_plastic can
plastic can.jpg (97.44 KiB) Viewed 3452 times
johnwang
Post by johnwang »
tutorial/04_hyperelastic_spring
johnwang
Post by johnwang »
tutorial/03_hyperelastic_cylinder
johnwang
Post by johnwang »
tutorial/09_contact_hertz
