Ticket #6131 - Can't save color
Moderator: bernd
johnwang
Re: Ticket #6131 - Can't save color
Post by johnwang »
jnxd wrote: Sat May 07, 2022 8:52 am The .FCStd file is a zip folder (just open with your archive software like winzip, or change the filename to .zip). In that you can see
Thanks, learnt new thing. Never touched FC file structure.
For UNV file, Node is under section 2411. Element under section 2412.
From here https://www.eng-tips.com/viewthread.cfm ... 3ee226a8dc
Universal Dataset Number 2412
Status: Current
Owner:  Simulation
Revision Date: 14-AUG-1992
Record 1:        FORMAT(6I10)
                 Field 1       -- element label
                 Field 2       -- fe descriptor id
                 Field 3       -- physical property table number
                 Field 4       -- material property table number
                 Field 5       -- color
                 Field 6       -- number of nodes on element
Record 2:  *** FOR NON-BEAM ELEMENTS ***
                 FORMAT(8I10)
                 Fields 1-n    -- node labels defining element
Record 2:  *** FOR BEAM ELEMENTS ONLY ***
                 FORMAT(3I10)
                 Field 1       -- beam orientation node number
                 Field 2       -- beam fore-end cross section number
                 Field 3       -- beam  aft-end cross section number
Record 3:  *** FOR BEAM ELEMENTS ONLY ***
                 FORMAT(8I10)
Records 1 and 2 are repeated for each non-beam element in the model.
Records 1 - 3 are repeated for each beam element in the model.
I opened the UNV file,
  2412
         1        41         2         1         7         3
         1         2         3
         2        41         2         1         7         3
         2         4         3
    -1
The Field 5 of Record 1 is color. Here = 7. I tried to change it to another value, no effect.
Where in the code write out this unv file? or maybe the import part ignored the color? Or FemMesh obj doesn't store this color?
Cheers,
John
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
jnxd
Post by jnxd »
johnwang wrote: Sat May 07, 2022 9:52 am The Field 5 of Record 1 is color. Here = 7. I tried to change it to another value, no effect.
The color appears to be stored in GuiDocument.xml. I saved a copy of the file with a "random color" set and compared the contents of the zip folders (see attached; as mentioned before .FCStd files are simply zip folders). Of the three files in each, the UNV file was the same but there was a difference in GuiDocument.xml.
diff -u --label \#\<buffer\ GuiDocument.xml\<minimal\>\> --label \#\<buffer\ GuiDocument.xml\<minimal-1\>\> /tmp/buffer-content-1L4dZf /tmp/buffer-content-MQreLX
--- #<buffer GuiDocument.xml<minimal>>
+++ #<buffer GuiDocument.xml<minimal-1>>
@@ -38,10 +38,10 @@
                     <Integer value="0"/>
                 </Property>
                 <Property name="ShapeColor" type="App::PropertyColor" status="1">
-                    <PropertyColor value="4289921024"/>
+                    <PropertyColor value="4206535424"/>
                 </Property>
                 <Property name="ShapeMaterial" type="App::PropertyMaterial" status="1">
-                    <PropertyMaterial ambientColor="858993408" diffuseColor="4289921024" specularColor="0" emissiveColor="0" shininess="0.2000000029802322" transparency="0.0000000000000000"/>
+                    <PropertyMaterial ambientColor="858993408" diffuseColor="4206535424" specularColor="0" emissiveColor="0" shininess="0.2000000029802322" transparency="0.0000000000000000"/>
                 </Property>
                 <Property name="ShowInTree" type="App::PropertyBool" status="1">
                     <Bool value="true"/>
There was also a difference in Document.xml but the difference was just in version and timestamps.
minimal.FCStd
(2.45 KiB) Downloaded 25 times
minimal-1.FCStd
(2.46 KiB) Downloaded 26 times
johnwang
Post by johnwang »
UNV 2412 element data are READ from here into SMESH, seems only element type and node data.
https://github.com/FreeCAD/FreeCAD/blob ... h.cpp#L165
And SMESH data are WRITTEN to UNV 2412 element from here:
https://github.com/FreeCAD/FreeCAD/blob ... h.cpp#L125
How SMESH is colored?
Can someone please test git commit a5ff515 and report back?
@johnwang
johnwang
Post by johnwang »
Kunda1 wrote: Wed May 25, 2022 7:10 pm Can someone please test git commit a5ff515 and report back?
@johnwang
Still the same.
I downloaded the two changed files and compiled.
2>ViewProvider.cpp
2>MeshSelection.cpp
2>Generating Code...
2>   Creating library H:/bjFreeCAD/src/Mod/Mesh/Gui/Release/MeshGui.lib and object H:/bjFreeCAD/src/Mod/Mesh/Gui/Release/MeshGui.exp
2>MeshGui.vcxproj -> H:\bjFreeCAD\Mod\Mesh\MeshGui.pyd
========== Build: 2 succeeded, 0 failed, 5 up-to-date, 0 skipped ==========
