Feature #6081 - Directly start Paraview from inside FreeCAD
Moderator: bernd
HoWil
Post by HoWil »
bernd wrote:
HarryvL wrote: Sun Feb 09, 2020 3:28 pm
I use paraview from time to time, also in combination with FC+Elmer.
What I would love to see is some functionality to directly start Paraview from within FC.
One would need to specify the folder where to look for .vtk files and/or which Paraview-state-file to use.
I have done this years ago with macros for a parameter study in FC but would love to see some semi-automated integration into FC.
BR,
howil
Reason: Added GH ticket number to thread title
bernd
Re: directly start Paraview from inside FreeCAD
Post by bernd »
HoWil wrote: Mon Feb 10, 2020 6:20 am
BR,
howil
It should be doable as a own FreeCAD FEM utility. We do not need to specify a folder. What I would suggest is selecting a result object in FreeCAD and press the paraview utility icon. In background FreeCAD exports the vtk file and opens paraview. The other possibility would be directly open paraview with the result file created after the solver has finished without even press the paraview icon tool.
But all this should be i a separate topic IMHO. Should I move them in a separate topic howil?
bernd
HoWil
Post by HoWil »
bernd wrote: Mon Feb 10, 2020 8:20 am But all this should be i a separate topic IMHO. Should I move them in a separate topic howil?
bernd
You are completely right.
bernd
Post by bernd »
done
bernd
Post by bernd »
HoWil
Post by HoWil »
Isn’t this commit l related to TIE or what can we expect? It is to much come to read it on the mobile.
UR_
Post by UR_ »
bernd wrote: Mon Feb 10, 2020 8:20 am ... exports the vtk file and opens paraview.
Please consider, that starting paraview has to be done via .bat file under certain circumstances.
Especially under windows and usage of hires monitors, some additional environment variables are needed.
set QT_AUTO_SCREEN_SCALE_FACTOR=2
start paraview.exe
exit
Otherwise started instance will be quiet unusable, because of unrecognizable icons.
That's valid only for version up to 5.7
I've no experience with upcoming version 5.8
bernd
Post by bernd »
UR_ wrote: Tue Feb 11, 2020 8:18 am
thanks for the information. I assume this is important for windows only?
bernd
Post by bernd »
HoWil wrote: Tue Feb 11, 2020 7:27 am
Just to show how to add a new command in FEM as I will not have the time to implement this in the near future. To much to do at the moment.
bernd
bernd
Post by bernd »
It mitght be useful to add a issue on mantis to not forget about this.
