yes
Ticket #3932 - Selecting solids on interior of CompSolid
Moderator: bernd
Re: Selecting solids on interior of CompSolid
Hi everyone!
I have the same issue on selecting the inner solids. I followed the same tutorial.
OS: Windows 10
Version: 0.19.16274
Build type: Pre-release
Locale: Russian (ru_RU)
OS: Windows 10
Version: 0.19.16274
I just ran into the same problem and did the following: https://forum.freecadweb.org/viewtopic. ... 55#p300855
Hope it works for you!
Baltasar
Baltasar
Be aware that the workaround affects the mesh region mechanism.
Selecting the original solid instead of the compound filter part, gmsh does not create the mesh anymore and states:
Solid <Solid object at 0x55e4db172200> not found in: <CompSolid object at 0x55e4dc2402c0>
Problem: For the geometry of the following shape was no Shape found: <Solid object at 0x55e4db172200>
The reference Shape is not a child nor it is the shape the mesh is made of. : <Solid object at 0x55e4db172200>
Best
Baltasar
Freecad Info:
OS: Debian GNU/Linux buster/sid
Version: 0.18.
Python version: 2.7.16rc1
Qt version: 5.11.3
Best
Baltasar
Freecad Info:
Version: 0.18.
Qt version: 5.11.3
this happens normaly if you did a mistake ... mostly they are not obvisous by default. Would you post the file? As I said this methode is not failsafe!
FYI, I have worked around this issue by just pulling all of the solids of a CompSolid out as shapes, and assigning all materials and boundary conditions to these shapes.
I had no success in trying to use the inputs to the boolean fragments. Such an approach just threw errors finding the appropriate solids during meshing.
A simple script to pull out the solids for selected shapes is:
for sel in App.Gui.Selection.getSelection():
try:
solids = sel.Shape.Solids
except:
continue
for solid in solids:
Part.show(solid)
Re: Ticket #3932 - Selecting solids on interior of CompSolid
issue #3932: FEM - Selecting the interior solids of CompSolid
Seem to be no more difficulties since Link merge
version:
Version: 0.19.18194 (Git)
Hash: f312878452bd25036f499b19bf0a9b6ea486e86a
Python version: 3.7.3
Qt version: 5.12.1
version:
Qt version: 5.12.1
Any progress on this?
Nice finding. But until now this does only work for faces, isn't it?
Can you please extend the selection dialogue for selecting solids. Solids inside solids is here the supreme discipline. Please see the attached 'boolean fragments' model as a start point where a Cube is inside another Cube and both were mergede. Selecting the inner cube is essential for e.g. the definition of different material settings.realthunder wrote: ↑ ping
*Whichlist*Switching through the "selection items" with turning the mouse wheel whould a fast way to do selections.*EndWhichlist*
BR Howil
- Screenshot from 2020-01-20 10-25-02.png (191.05 KiB) Viewed 2297 times
- booleanFragments.FCStd
- (9.67 KiB) Downloaded 72 times
