fcFEM - FEA from start to finish
Moderator: bernd
HarryvL
Re: fcFEM - FEA from start to finish
Post by HarryvL »
OOPS ...
<class 'ModuleNotFoundError'>: No module named 'scipy'
I thought this was a standard FC dependency.
And I see I also missed "sksparse" for the solver.
Sorry
ppd
Post by ppd »
Fixes incoming:
Set path to Gmsh exe automagically: https://github.com/FreeCAD/FreeCAD-snap ... 8e8d3bb8e1
The /dev/shm issue has been solved by https://github.com/FreeCAD/FreeCAD-snap ... 0b2fcd69a8
scipy: https://github.com/FreeCAD/FreeCAD-snap ... 16ca99feff
Try it tomorrow.
Ah, and also: If you encounter problems or deficiencies with the snap, please report them at https://github.com/FreeCAD/FreeCAD-snap/issues if possible. It's a much better tracker for me than the forum, and therefore stuff usually gets fixed quicker.
Try FreeCAD from the Snap Store: Stable releases (in latest/stable) & daily builds (in latest/edge). Supports installing additional python packages via pip!
HarryvL
Post by HarryvL »
OK will do ... did you catch my sksparse comment?
OVER AND OUT
HarryvL wrote: Tue Jun 21, 2022 6:31 pm OK will do ... did you catch my sksparse comment?
Yea we saw it ;)
HarryvL
Post by HarryvL »
ppd wrote: Tue Jun 21, 2022 6:06 pm Try it tomorrow.
Thanks, that works very well !
ELASTIC:
Screenshot from 2022-06-23 10-57-12.png (64.9 KiB) Viewed 2124 times
COLLAPSE:
COLLAPSE:
Screenshot from 2022-06-23 10-56-36.png (59.91 KiB) Viewed 2124 times
HarryvL
Post by HarryvL »
And it wouldn't be complete without ParaView ;)
ppd
Post by ppd »
HarryvL wrote: Thu Jun 23, 2022 9:07 am Thanks, that works very well !
Looks good. I'm always quite flexible about those requests. :D
This will land in latest/edge (and in latest/edge/toponaming) tomorrow.
NewJoker
Post by NewJoker »
@HarryvL It's great that fcFEM will be developed again. FreeCAD may benefit significantly from having a solver designed specifically for it.
Do you plan to keep updating the GitHub repository ?
https://github.com/HarryvL/fcFEM
HarryvL
Post by HarryvL »
NewJoker wrote: Thu Jun 23, 2022 9:43 am Do you plan to keep updating the GitHub repository ?
Hi, yes is the short answer.
I will get a standard/basic version ready first (that can reproduce most cases of this thread), with a set of test cases, as was asked for.
After that I will reinstate a specialized version for concrete and further develop that into a robust tool for conceptual design.
What experimental versions come after that is only limited by time, ideas, requests and feasibility.
@HarryvL both dependencies are now in the Snap, please test and report back. Thanks!
