fcFEM - FEA from start to finish
Moderator: bernd
-alex-
Re: fcFEM - FEA from start to finish
Post by -alex- »
Kunda1 wrote: Sun Nov 08, 2020 10:53 am it would be awesome if this code doesn't rot, but actually gets in to master.
+1
cadcam
Post by cadcam »
That is a great shame, is there a posting indicating why development
stopped. I notice HarryvL is still active in the forum
Progress looked very impressive and being in Python
might lead to help from the community, if only in i/o UI.
If it is 'dead', I wonder if https://wiki.freecadweb.org/FEM_Solver
should be updated
Best Wishes
bernd
Post by bernd »
More important would be to turn some of the examples of Harry into unit tests, to make the code more robust in the regard of changes in master. I would go for this, once the code runs again.
Even if Harry would not continue to develop, this is a great base for others.
johnwang
Post by johnwang »
It's better to separate the solver part and the interaction part with FC. It should also run purely on Python. In this way, there may have wider interests to expand it.
HarryvL
Post by HarryvL »
I am easing back into it, but won't have as much time as before.
First trying to get the FC 0.20 to work on my virgin laptop with UBUNTU 22.4 :shock:
bernd wrote: Sun Nov 08, 2020 11:58 am More important would be to turn some of the examples of Harry into unit tests, to make the code more robust in the regard of changes in master ...
johnwang
Post by johnwang »
HarryvL wrote: Fri May 06, 2022 9:50 am I am easing back into it, but won't have as much time as before.
Excellent. I can help testing under windows. Good to learn.
-alex-
Post by -alex- »
Hi Harry, glad to see you're back in FC business :-)
-alex- wrote: Fri May 06, 2022 10:21 am
Indeed!
This is exciting!
HarryvL
Post by HarryvL »
@Bernd
I am looking to fix extraction of material parameters on an element-by-element basis. I used to do this in a clumsy way via the "get_several_member" method in the femtools.membertools module and the FemInputWriter method in the femsolver.writerbase module. However, it looks like both modules have had a major re-write since I last used fcFEM.
Rather than re-working my clumsy extraction of material parameters, is there (now) a better way to extract them by element?
Jee-Bee
Post by Jee-Bee »
HarryvL wrote: Sat May 07, 2022 9:37 am ...
You have to ping Bernd the last time bernd logedin was on 12 April
