Concrete branch ready for testing
Moderator: bernd
bernd
Re: Concrete branch ready for testing
Post by bernd »
in your FreeCAD git dev repo:
# add my repo as a remote repo (you only need to to this once!)
git remote add bernd https://github.com/berndhahnebach/FreeCAD_bhb
# fetch my repo (you need to do this every time there have been changes in my branch)
git fetch bernd
# if you only would like to test my femconcrete
git chechout remotes/bernd/femconcrete
# there will be the message in the regard of detached head because you are not in a local branch
# compile and test and what ever
# a few days later or a few hours later, when I have made change, just
git fetch bernd
git checkout remotes/bernd/femconcrete
# compile test ...
# if you would like to add an own commit and are in my remote repo in detached head
git checkout -b somenameharrywouldliketogivehisdevelopment
bernd
Post by bernd »
HarryvL wrote: Sat Jun 15, 2019 2:32 pm
bernd wrote: Sat Jun 15, 2019 12:28 pm
HarryvL wrote: Sat Jun 15, 2019 10:46 am "Data points in all amplitudes" ??
might be because of this https://forum.freecadweb.org/viewtopic. ... 10#p314611 open the dat file. You will find the sum of reaction forces.It is a great control of load sum.
:shock: only on femconcrete, or on master too?
That's a good addition, but is it a bug or should I change some of my input to make it work? Currently FC freezes at the end of an CCX analysis.
everything runs smooth here ...
bernd
Post by bernd »
- compile femconcrete
- start FreeCAD
- run code
from femexamples.manager import *
doc = run_rcwall2d()
bernd
Post by bernd »
HarryvL wrote: Sat Jun 15, 2019 10:06 am I am not sure what "reinforce_ratio" does/did. Is it this the minimum reinforcement ratio from input? That what is called r0 later on?
yes
HarryvL wrote: Sat Jun 15, 2019 10:06 am And reinforce_yield? Is this the input value of the yield strength of the steel? It is deleted and then added back in?
yes, this is just because of the way diff formats the changes.
HarryvL wrote: Sat Jun 15, 2019 10:06 am And where does that get linked to fy in the code? Anyway, it is probably easiest for me to just run a few test cases.
here is reinforce_yield https://github.com/berndhahnebach/FreeC ... #L448-L451 linked to fy https://github.com/berndhahnebach/FreeC ... ls.py#L607
HarryvL wrote: Sat Jun 15, 2019 10:06 am Can I pull this from your femconcrete branch?
yes, it has the latest concrete dev and it is rebased on FreeCAD master
HarryvL wrote: Sat Jun 15, 2019 10:06 am Deletion of scxx, yy, zz looks ok.
cool
bernd
Post by bernd »
just another small improvement for better readable code ... https://github.com/berndhahnebach/FreeC ... t/49a71442
HarryvL
Post by HarryvL »
bernd wrote: Sat Jun 15, 2019 8:12 pm in your FreeCAD git dev repo:
git fetch bernd
git fetch bernd
# compile test ...
Thanks, that worked.
HarryvL
Post by HarryvL »
bernd wrote: Sat Jun 15, 2019 8:19 pm - compile femconcrete
- start FreeCAD
- run code
This works Bernd. It also works with my other old files. There must have been something wrong with the old file for the one case I tried first
bernd
Post by bernd »
what else is needed before merge into master?
From my point we should go for a merge!
HarryvL
Post by HarryvL »
bernd wrote: Sun Jun 16, 2019 11:45 am what else is needed before merge into master?
As far as I can see this is production ready. Hopefully others will give it a try so further bugs can be found
bernd
Post by bernd »
